JustinW.73 224 #1 Posted February 3, 2015 (edited) Hey guys I have a raider 12 with the manual labor lift handle and that thing is a bear to lift the snowblower. I tried the spring on the lifting rod but that kept the blower from being able to stay on the ground. Has anyone done this to their raider and if so what did you use. Or if anyone has dimensions on the original hydraulic that would be great. I need the full extended length (center of holes when the push rod is fully extended) and the od of the cylinder. And would a 320 lb capacity actuator work? I found one on ebay for 50 bucks and I thought I'd give it a try. I thing I would have to cut the end of the rod so its like the original wh rod. Thanks for any help! Edited February 3, 2015 by JustinW.73 Share this post Link to post Share on other sites
