51Chevy 66 #1 Posted January 28, 2015 Is a Kohler k90 and kohler k91 carb the same? I have a Kohler k90 on my wheel horse rj35 and need to rebuild it and change the float but only see kits for the 91.... Can I order that? Share this post Link to post Share on other sites
slammer302 2,157 #2 Posted January 28, 2015 Should be the same if its a carter Share this post Link to post Share on other sites
51Chevy 66 #3 Posted January 28, 2015 Yes it is Carter N Share this post Link to post Share on other sites
slammer302 2,157 #4 Posted January 28, 2015 Then you should be fine with the kits on ebay Share this post Link to post Share on other sites
51Chevy 66 #5 Posted January 28, 2015 Ok thanks, so k91 would work? Share this post Link to post Share on other sites
slammer302 2,157 #6 Posted January 28, 2015 Yep the k90 k91 k161 k181 all use the same kit in the carter carbs I believe the ventri is just a little smaller on the k90 and k91 I believe there a #20 and the 7&8 is a #22 1 Share this post Link to post Share on other sites
