Please help with pictures of D-250 Dash & Console
					By
Ironman,   in Restorations, Modifications, & Customizations
Similar Content
			By blu_stang
Hi All, It's time for me to sell the D-250 I've had for the last 8 years. It’s useable as is, or would be a great project bundle for further restoration.
I am selling a large package: the running tractor, a refurbished snowblower (48”), parts snowblower, mower deck (60”), tiller (40”), front plow blade (60”), Cat 0 3-Point Hitch with adjustable top link, WH 3-Point tool bar, wheel weights and tire chains. Also included is an extensive part collection, nearly a second tractor worth. I will include the original manuals, an original 1976 sales brochure, and repair manuals for the tractor and the engine. I made electronic copes of all of the above, and stored the paper copies to prevent further wear. This is one of the most complete D-250 tractor/attachment bundles I’ve seen.
Some highlights from the available parts: Frame rails, extra engine, water pump, extra transaxle, extra gears, including worm gears (stored in oil bath), Front wheel set, carburetor, carb rebuild kit, rebuildable original radiator, extra radiator overflow bottle, rebuilt alternator, new voltage regulator (I was planning to change over to an alternator setup from the generator), new in package Renault engine seals, new PTO seals, ignition maintenance parts. There are also many panels, frame pieces, cables, levers, tubes (lines) and hardware in the collection.
The tractor engine runs smooth. There are around 1050 original hours on it; It’s a 1976 edition. Everything works, except the dash lights and the rear lights (disconnected b/c of fender). I just haven't sorted out the wiring, but it is all there. Headlights are good and working, as are all of the gears and levers. The four tires are nearly new Carlisle Multi Trac, with nubs still on them. The rear tires have been filled (ballasted) with Rim Guard for extra traction. The hydraulic pump, front PTO clutch and brakes operate but could use a tune up. I’ve used it for mowing and snowblowing on hills, driveway and around my land. I don’t have an original WH seat. The snowblower was rebuilt a few years back, and assembled with all new hardware and bearings. The mower deck gearbox was professionally serviced recently, and has a new set of blades with only a half dozen mows. The rear fender needs a repair, but all pieces are available. The plow and tiller are due for restoration. The Points, Condenser and rotor have all been replaced and tuned in. The battery is good. I've rebuilt the carb, replaced the fuel pump and changed out the plugs within the last 30 hours. The replacement radiator is from a Kawasaki engine; it was installed with new hoses. There are also new custom hydraulic hoses and a new hydraulic lift cylinder.
Here's a video of me mowing, this past summer.
Transporting this haul in one trip will require a pickup truck and a large trailer.
			By Wheel Horse 3D
I recently began pondering what all i could 3d print to dress up a horse. I'm pretty good with deaign sofware and came up with a couple small items to start, and figured i can easily print things like headlight covers, hood ornaments, and badges of all sorts.Then I wondered if maybe rather than a decal if i 3d printed an embossed plate or sorts with the appropriate graphics in 3d. These could be enamel painted, or printed in a silver that would give a brushed nickel type of finish.
Here's a couple photos of what ive created thus far in some gray test material. Please let me know what ya think.
			By 67 WH 877
Question....Decal placement, before or after clear coat? Which is the best for longevity?
			By Larry Danler
Howdy. I am new to garden tractors. I have a Wheel Horse 1277 with just a mower deck. I am looking for instruct ions on how the different implements attach, which ones (names will hook up to different tractors and how the hydraulics and/or the pto systems work. Anyone know of a book on instructions. ? HELP! thanks, Larry
			By ChaplainManny
Hi. I'm Chaplain Manny. I was wondering if you supply the decals for the gt14, the kohler k321 engine?
If you do, could you give me a quote, and tell me how long is the turn around?
Thank you.
