mailman 1 #1 Posted October 23, 2008 I was looking into replacing the headlights on my c-series. It looks as though they are attached by rivets. Do they need to be drilled out and then screwed back? I don't have a rivet gun. Is that what you guys do? Share this post Link to post Share on other sites
MaineDad 87 #2 Posted October 23, 2008 You should be able to remove the screws on the front plastic plate to get at the lights. The rivots are to hold the light assembly not the actual lights. Share this post Link to post Share on other sites
kj4kicks 154 #3 Posted October 23, 2008 Hi Eric, the bulbs are just standard 1156's, the same as the reverse lights in older cars. Just push down and give a half twist to remove them. (After you unscrew the lense lol) Share this post Link to post Share on other sites
mailman 1 #4 Posted October 23, 2008 I guess I should have been more clear. The headlight assembly itself is what I want to replace. I removed the "bezel" and the bulbs. The headlight assembly itself is held on by two rivets. Share this post Link to post Share on other sites
kj4kicks 154 #5 Posted October 24, 2008 Hi Eric, Yes, you'll have to drill out the rivets. Why do you need to change it? As long as it isn't to rusty, the sockets can be repaired. The wiring and terminals are available at most major parts stores. It's an easy fix. Cut the wires, push them and the seperator disc up through the socket, and install the new stuff. Share this post Link to post Share on other sites
tasmi01 3 #6 Posted October 24, 2008 I agree you don't have to drill out the rivets unless the sockets are bad. I had to just pull the wires through on the electro 12 and clean the socket with steel wool and I actually made my own wire set by using trailer wire and large aluminum rivet heads the seperator I made from some old rubber tubing I had laying around and they seem to work great. :banghead: Share this post Link to post Share on other sites
Duff 206 #7 Posted October 25, 2008 Hi, Eric, Did you see this on eBay? Item #190261676932. Duff :banghead: Share this post Link to post Share on other sites
