slammer302
Help identifying engine
slammer302
Got this motor off a 552 or 502 it has two I'd tags on it wanted to see what you guys thinke09964f6a2afc7e55d2e9baa4875b917.jpgdc4082e10310731e9ea04364ea86b2c7.jpg27856a831f41ed39a6423f8134112ea1.jpg24e86a157a109ade1091fa334ae0c40b.jpg
slammer302
One tag says HT55B and the other says H55A 1170
JustinW.73
That is a 5 hp tecy big block. I have one and it looks just like that.
slammer302
Would this be considered a Clinton motor
JustinW.73
Nope just a standard big block Tecumseh 5 horse.
JustinW.73
How I know this HT55B. T is Tecumseh, one 5 is stroke and the other is diameter if I remember right, making it a 5 hp rated, the B is big block, H is flat head.
slammer302
Thanks
TT
Wow :scratchead:
No.
H and / or HT is crankshaft orientation (Horizontal) V would denote vertical shaft.
55 = 5.5hp
The letter suffix included in the basic model number (A, B, C, D, etc.) is the change progression in the basic model.
1170, 3088, 3089, etc. is the spec number (used to identify application and specific parts from the manual)
P indicates a Phelon magneto  W (or no letter) would be a Wico magneto.
TT
Not guaranteed 100% accurate, but this is what I seem to remember:
The HT55B~3088P tag may belong to an early-production 502 engine. The 1962 32R lawn Ranger and later 502 models used an HT55C engine. (all I've ever seen)
The H55A-1170 tag / shroud belongs to a 1960 550 "Suburban".
They are often referred to as Lauson engines even though Tecumseh bought Lauson out a few years prior.
