Anthony Wendover 124 #1 Posted October 22, 2008 How the hell to you get this thing off? lol I have tried a bunch of pullers and i cant get the damn thing to budge. What puller should i try using? Once i get this off i can open the case and order all my parts after i inspect her.. Attached Image Share this post Link to post Share on other sites
jerrell 1 #2 Posted October 23, 2008 :banghead: Hi Andy, I did not mess with the hydro unit, i cleaned it up real good and painted it, i did use a solution of 1 part diesel with 3 parts of new oil and flush the system using a small motor i had, i threw oil everwhere but i got it cleaned out and put on new filter and oil, i checked the lift cynlinder on both hoses at the extened position and the closed position and had good clean oil so i think i flushed it pretty good. i used the cheap oil to flush because i knew i would throw it away and that the good oil would blend with it. back to your ? you might try soaking with WD 40 and use a sharp screwdriver to pry up on it. like i said i didn't mess with mine. i am not versed with hydros but will be this winter, i have a hustler 295 and plan on rebuilding the left side motor and the pump, i got a manual and it shows all kinds of O rings and springs in side. i got a friend who works at a hydro shop and he assured me we could rebuild them . takes special o rings, springs, and ball check valves, why are you taking yours apart,???? jerry Share this post Link to post Share on other sites
Anthony Wendover 124 #3 Posted October 23, 2008 I want to take it apart and replace some things. I don't wanna rebuild the tractor and have the hydro break down or transaxle a month after i think i am done lol.. Rather be safe then sorry and be good for another 20 years.. I'm not sure what to replace though. Should i just get barrings and seals? But i still need to figure out how to get this damn thing off though lol Its been the biggest problem of this whole tear down... Share this post Link to post Share on other sites
