tom4400
518 H mower deck
tom4400
I'm in the process of rebuilding my swiss cheese of a mower deck.  I'm trying to remove the spindles and aren't sure if the pullies are threaded on or if they slip on. Do I need to use a puller and maybe some heat ?  Thanks.Tom.
daveoman1966
Some pulleys have a 'pull-ring' on the top and a 'power steering pulley' remover tool works well. Typically these pulleys use a woodruff key with the spindle shaft.(Autozone will rent you this puller.)
Other pulleys are press-fit requiring to drive the spindle shaft down thru the spindle, while supporting equally the three spindles on a base of some kind. I use 3 large coffee cans, paint cans would also do. Once supported in the 3 cans, remove the top grease zerk and using a brass hammer as a drive pin, SMACK the brass hammer with a BIGGER hammer. Don't be shy....SMACK IT HARD. Usually the pulley will pop off the shaft this way and the shaft will drop thru the housing.
Others may say to support the base of the spindle housing to stop the shaft from breaking off the very end of the housing. I have found that NOT NECESSARY and I have never broken a housing in the way they've described...not in a 100 times or so.
Edited by daveoman1966
tom4400
 Thanks for the quick reply. I appreciate it . Thanks Tom.
  • Similar Content
    • PAguy
      By PAguy
      Hello gents!
      I find myself with a question for the forum before I go down the path of ripping my deck apart in the middle of the season.
      I have a 42 inch rear discharge 78350 that seems to have developed a crack at the center spindle (photo attached). At first I thought I had unbalanced blade issue bc the deck will vibrate something fearce. Long story short took it off got everything sharp and freshly greased. Started it up and it had the vibration again that reverberates through the deck. Now it's not as as bad as before but at the wrong angle or first starting it just vibrates loudly. So looked around and found the crack at the center spindle.
      Debating if a simple weld would be sufficient for this crack or it would need more extensive repair? I don't weld myself but before I bothered the guy that farms the property thought I would ask here for thoughts if someone has had this issue since I was not seeing something in the forum.
      Appreciate your guys help and thoughts.
    • MSBiker
      By MSBiker
      Well it looks like I'm out of luck. I have been looking for blades for my Lawn Ranger and having zero luck. I have tried Wheel Horse part numbers 7908, 7909. Toro part numbers 8777, and 53322 and no one has anything like this. I was thinking about doing a cut down, but finding right hand and left hand blades seems to be the problem.
      Anyone making blades, constructing blades, got a work around, etc? My blades are usable, but that is about it.
    • Brockport Bill
      By Brockport Bill
      48" Mower Deck - Side Discharge model # 78361 -- # 312000163. This mower is listed as being manufactured at the near end of Wheel Horse production for this deck in 2012. This mower is in very good condition used only one season on small yard. Well cared for and stored indoors. The deck has double right side pulley for optional bagger attachment. Any owner who cares for this mower will have a great investment of a classic WH deck to last decades. Cash pick up Poughkeepsie, NY area. No returns. Please send p.m if interested
    • jmack
      By jmack
      What’s the correct v-belt size for a xi drive belt connecting to a 60” deck?
      Just shredded mine today.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I’m having trouble with getting my deck to raise up and lock and I think it might have to do with the deck being incorrectly set up.
      Based on the picture, does my mower deck look incorrectly positioned? That is, should the pivoting support bar be positioned above or below the wheel support pin?
      Brian
