mrc 1,057 #1 Posted November 12, 2014 here is a C120 i got for my great grandson. he is only 4 years old now. hopefully they won't outlaw gasoline before he can ride it. just did a tranny swap because some PO welded the hubs to the axles. how would you change an axle seal with that setup? also in the pics is my 414-8 going to their winter storage home. (a friend's garage). hope you guys like the pics. mike in mass. 9 Share this post Link to post Share on other sites
Geno 1,930 #2 Posted November 12, 2014 Very nice looking tractors, you got your grandson off to a good start! 1 Share this post Link to post Share on other sites
JERSEYHAWG / Glenn 4,528 #3 Posted November 12, 2014 Mike,,,,,,,,,,,very very nice. Godd choices and thanks for sharing. Glenn 1 Share this post Link to post Share on other sites
slammer302 2,157 #4 Posted November 12, 2014 That looks like a nice setup Share this post Link to post Share on other sites
KC9KAS 4,746 #5 Posted November 12, 2014 Very nice looking C Share this post Link to post Share on other sites
daveoman1966 3,882 #6 Posted November 12, 2014 The axles are hardened and I don't know if a sawzall would cut them off. If the hubs are NOT tight against the trans case, MAYBE you can remove the 6 trans bolts to split it open far enough to reach in with long box-end wrench(s) and remove the 4 differential bolts. Doing that will allow the differential to come completely apart, then you can pull each axle out of the trans unrestricted. Share this post Link to post Share on other sites
PaulC 342 #7 Posted November 12, 2014 vey nice tractors!!! you must really trust that friend of yours, if you stored those in my garage your hour meter might mysterious read higher when you came to get it id also like to see a pic of the welded on hubs I don't see why someone would ever do that?? I think the hubs are cast iron too which is not the easiest thing to weld Share this post Link to post Share on other sites
Racinbob 12,803 #8 Posted November 13, 2014 Beautiful tractors I'm with Paul on welding the cast to the steel axles. Plus I'm sure it ruined the seals. You can cut the axles quite easily. I had to with one of mine and a hacksaw is all it took. Share this post Link to post Share on other sites
mrc 1,057 #9 Posted November 13, 2014 well guys the hubs were not just tack welded to the axle. they looked like they were double pass welded to the axles. due to winter coming on i have been cleaning the garage and just got rid of all my scrap metal. why someone would do that is beyond me too. maybe the keyway slot was worn? maybe some PO had bad keys? the welding bead on the right hub was almost touching the case. not much room on the left either. i cut thru the axles with a cutoff wheel on an angle grinder. best regards men. mike in mass.i Share this post Link to post Share on other sites
