mbarb54 8 #1 Posted November 8, 2014 (edited) With winter around the corner, I decided to do a preseason check on my 310-8 which has a 42" single stage snow thrower attached. The tractor started up fine but when I engaged the PTO clutch the snow thrower auger did not engage.and while the motor was running it was clearly straining. I then quickly disengaged the clutch. I checked the auger and at first it wouldn't move at all. Then with effort I was able to get it to move back and forth maybe 1/3 turn, but that's about it. The chain is okay and not off the sprocket. Any ideas on what the problem might be is much appreciated I need to be ready when the white stuff falls. Thanks in advance. Michael in WI Edited November 9, 2014 by mbarb54 Share this post Link to post Share on other sites
Ed Kennell 42,081 #2 Posted November 8, 2014 (edited) Has the drive chain jumped off a sprocket and jammed the auger ? Edited November 8, 2014 by ekennell Share this post Link to post Share on other sites
mbarb54 8 #3 Posted November 8, 2014 The drive chain appears okay. It has not jumped the sprocket. Share this post Link to post Share on other sites
squonk 43,864 #4 Posted November 9, 2014 One of your jack shaft or sprocket bearings may be seized. I would take the master link off the chain and check everything to be sure. If everything is original it may be time for an overhaul. 1 Share this post Link to post Share on other sites
mbarb54 8 #5 Posted November 9, 2014 I bought the snow thrower about 3-4 years ago. It had been rebuilt and reconditioned. I suppose bearings could still seize. Thanks for the tip. Share this post Link to post Share on other sites
Ed Kennell 42,081 #6 Posted November 9, 2014 One of your jack shaft or sprocket bearings may be seized. I would take the master link off the chain and check everything to be sure. If everything is original it may be time for an overhaul. With the chain off, you can isolate the problem. I would also check the auger and housing for clearance at the center of the auger. If you can turn it 1/3 turn, the auger may be bent. 1 Share this post Link to post Share on other sites
Forest Road 594 #7 Posted November 17, 2014 (edited) It's a good idea to change your chain every couple of years. They stretch and wear the teeth. $20 Is cheap insurance Edited November 17, 2014 by Forest Road Share this post Link to post Share on other sites
