rustykan
Throttle and Choke Cable Levers
rustykan
Re-installing the throttle and choke cable levers and I have a question. Which cable uses the lever that has detents on the movement? According to the before photos I have it back together correctly, but I'm not sure. I have the lever with the detents on the choke cable and the throttle cable has a smooth movement. Is this correct? Thanks in advance.
bmsgaffer
I do believe you have it correct.
None of the horses I own have detents on the choke, but on other pieces of equipment there are.
Geno
:text-yeahthat:    :handgestures-thumbsup:
rustykan
I wasn't totally sure about it, but really didn't want to take them off and switch them! Thanks for the confirmation!
