buckrancher 2,697 #177 Posted May 29, 2022 front wheels 6 6 Share this post Link to post Share on other sites
ebinmaine 80,449 #178 Posted May 29, 2022 Lookin' snazzy Brian 1 Share this post Link to post Share on other sites
buckrancher 2,697 #179 Posted June 9, 2022 completed the tear down one side was dry the other side still had some oil 6 5 2 Share this post Link to post Share on other sites
wallfish 20,547 #180 Posted June 9, 2022 3 minutes ago, buckrancher said: one side was dry Just a little bit! Not even a shiney spot in there 1 Share this post Link to post Share on other sites
ebinmaine 80,449 #181 Posted June 9, 2022 17 minutes ago, buckrancher said: dry WOW Share this post Link to post Share on other sites
buckrancher 2,697 #182 Posted June 10, 2022 everything in primer 7 6 1 Share this post Link to post Share on other sites
AMC RULES 37,259 #183 Posted June 10, 2022 Nobody does it better! 3 Share this post Link to post Share on other sites
wallfish 20,547 #184 Posted June 10, 2022 I'm always very impressed when going over to see Brian's stuff at the big show. Incredible detail to everything. 3 Share this post Link to post Share on other sites
rjg854 13,329 #185 Posted June 10, 2022 Looking good , Brian 2 Share this post Link to post Share on other sites
ebinmaine 80,449 #186 Posted June 10, 2022 Niiiiice 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #188 Posted June 11, 2022 I know where I am not parking my senior at the show… 6 Share this post Link to post Share on other sites
oliver2-44 11,708 #189 Posted June 11, 2022 Excellent work saving that Senior🤗 1 Share this post Link to post Share on other sites
buckrancher 2,697 #190 Posted June 11, 2022 rebuilt the brake backing plate replaced all the hardware brake activation shafts wear 5 Share this post Link to post Share on other sites
Horse Newbie 7,405 #191 Posted June 11, 2022 On 11/2/2014 at 1:48 AM, neil said: 2000 miles @neil… you cross the pond to come to the Big Show ? Share this post Link to post Share on other sites
buckrancher 2,697 #192 Posted June 12, 2022 paint and started reassembly 3 9 1 Share this post Link to post Share on other sites
buckrancher 2,697 #193 Posted June 12, 2022 (edited) brake parts and drum are from mid 1930's (ford) i believe they are called wide 5 brake drums Edited June 12, 2022 by buckrancher 3 8 Share this post Link to post Share on other sites
rmaynard 17,547 #194 Posted June 12, 2022 As usual, you are a magician. 2 Share this post Link to post Share on other sites
Snoopy11 5,731 #195 Posted June 13, 2022 25 minutes ago, rmaynard said: magician Indeed. We are not worthy, El Mago... Don 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #196 Posted June 13, 2022 I just want to know what is taking you so long….. 1 Share this post Link to post Share on other sites
953 nut 68,747 #197 Posted June 13, 2022 11 hours ago, buckrancher said: brake parts and drum are from mid 1930's (ford) i believe they are called wide 5 brake drums 1937 fords used that pattern. 1 Share this post Link to post Share on other sites
buckrancher 2,697 #198 Posted June 18, 2022 almost there 7 Share this post Link to post Share on other sites
rjg854 13,329 #199 Posted June 18, 2022 That sure is a beauty, Brian. 1 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,742 #200 Posted June 18, 2022 Looking very shiny buddy!! 1 Share this post Link to post Share on other sites
