BairleaFarm 344 #1 Posted October 14, 2008 Can you plow in manure? I figures spread the manure/straw mix on the ground and run over it with the plow Will that work? Is it the same with leaves? Do i doo it this fall so it can do its thing over the winter? How damp does the soil need to be to plow? I would assume dustiness means to dry? Share this post Link to post Share on other sites
Duff 206 #2 Posted October 14, 2008 Can you plow in manure? I figures spread the manure/straw mix on the ground and run over it with the plow Will that work? Is it the same with leaves? Do i doo it this fall so it can do its thing over the winter? How damp does the soil need to be to plow? I would assume dustiness means to dry? Don't know, David. My wife tells me I'm in deep s**t most of the time, but I haven't tried to plow it yet...... (Couldn't resist!) But on the serious side, I do till some of my leaves into my garden after I've mulched 'em up a little with either the tractor deck or my push mower. Seems to help aerate the soil come next spring. Mostly Maple and Oak. As long as it's not too dusty, I find tilling (and probably plowing?) when it's a little on the dry side is less work for the machine. Duff :banghead: Share this post Link to post Share on other sites
MaineDad 87 #3 Posted October 14, 2008 David, Click on this link and scroll down to the pumpkin patch post... http://www.gardentractorgardening.com/search/label/Tillage Share this post Link to post Share on other sites
BairleaFarm 344 #4 Posted October 14, 2008 So you do How about dampness? you soil looks more wet than dry. Share this post Link to post Share on other sites
linen beige 16 #5 Posted October 15, 2008 Can you plow in manure? Much more easily than you can plow out of it! But I would wait for a little rain. Our ground is more like concrete right now over here, I'd guess it's pretty dry in G'town too? Share this post Link to post Share on other sites
BairleaFarm 344 #6 Posted October 15, 2008 I'd guess it's pretty dry in G'town too? O yeah. i went to dig a hole and my shovel went ting when it hit the ground. Share this post Link to post Share on other sites
jerrell 1 #7 Posted October 16, 2008 :USA: yes you can plow the manure in the ground and it is best to do it in the fall, i my self turn the ground over with a big middlebuster with my belarus, down to about 12 inches, spread lime over the area then plow it under with the horse,, in the spring i spread manure or fertilizer and till it in, i did not have tomato plants i had tomato trees, needs lots of water here tho, my orka was so abuntdant i had to give it away, i had one sunflower plant that was as big as a barrel top. i have a little trouble with my horse plow, it has no adjustments to lower the point into the ground so i can only use it in loose soil, plan on getting a brintly or something with an adjustment, i to have soil like concrete when it is dry but with a couple of loads of manure it loosens up and works well. in fact my shop has a dirt floor and i sweep and it is just as clean and hard , i can move a floor jack around and not even scratch it up.. :banghead: Share this post Link to post Share on other sites
BairleaFarm 344 #8 Posted October 19, 2008 Do you think it would hurt to spread the poo and not till it in for a few weeks? I dont suppose it owuld do any harm other than killing the grass. Share this post Link to post Share on other sites
MaineDad 87 #9 Posted October 19, 2008 David, By leaving it out and not plowing it under, you will loose a lot of the nitrogen for the decaying process. It's best to till or plow it under as soon as possible. Share this post Link to post Share on other sites
