Similar Content-
			 By dannyo By dannyo
 Hi all. I am new to the Wheel Horse world and I have a question about attaching a tiller to my 875 before I start spending money. Based on what I've read so far, it sounds like I can use the RT-366 tiller without having the 8-3311 PTO assembly, is this correct? If so, does the RT-366 belt attach to the hydrostatic motor if there is a double pully (#6887) installed?
			 By D_Mac By D_Mac
 Picked this up today because I wanted the deck for my 875. The 875 has no deck so I figured this one is better then none at all. Question is what do I do with the rest of it??? 875, was told the engine needs rebuilding. Been sitting in a barn last 20+ years. Steering wheel is broke. Both front tires are shot and coming off the rims. Original paint. Plow needs the arm to turn the blade. Its repaired in a fixed position. Worth more in parts or as whole? Not sure I want a big project. What do you all suggest???
			 By KC9KAS By KC9KAS
 My 875 is missing the small spring that is attached to the cam/neutral plate.
 The part number is 1230 and NLA.
 Anyone have one or know the dimensions of the spring?
 Thank you!
			 By KC9KAS By KC9KAS
 ISO of hydro motion control lever bushings.
 These appear to be parts # 5666 (nylon) need 2, # 5983 (Nyliner) need 2, # MW2195 (bronze) need 1.
 Please PM me here.
 Thanks in advance.
			 By admin-(Admin) By admin-(Admin)
 1 page 196.25KB
 1 page 82.24KB
 Dated February 17, 1965
 232613 Kohler belt nla Use 231605
 232613 - Gates 7320 .41"x32.58" 36 degree or Napa 25-7320 .41"x32.58" 36 degree
 231605 - Gates 7315 .41"x32.08" 36 degree or Napa 25-7315 .41"x32.08" 36 degree
 1964 model 854
 1965 model 855
 1965 model 875
 Starter/generator belt
 Kohler 10hp, 12hp - 235262 (7345 Gates .410" x 35.09" 36 degree) (25-7345 Napa .410" x 35.09" 36 degree)
 Wheel Horse 1593 (3L x 34.4") - nla (Gates replacement 6735 3/8" x 35" 38 degree)
 1964 model 1045
 1964 model 1054 - Not in PSB - Wheel Horse # 1593 nla {3Lx34.4"} - Gates 7340 .410"x34.58" 36 degree or Napa 25-7340 .410"x34.58" 36 degree
 1965 model 1054A - Not in PSB - Kohler 235262 replaces 235528 [.41"x35.09" 36 degree] - Gates 7345 .41"x35.09" 36 degree or Napa 25-7345 .41"x35.09" 36 degree
 1965 model 1055
 1965 model 1075
