Sean Keys 57 #1 Posted October 27, 2014 The deck under my 1969 Wheel Horse 700 and :eek:1962 Cub Cadet Original are having some issues. Both machine have two blade decks. It seems like no matter what I try the blades hit each other. Even when I off set the blades they still manage to hit each other. It is the blades that are hitting each other, they are not hitting the deck anywhere. Has anyone else experienced this issue?? Anybody know how to fix it?? Share this post Link to post Share on other sites
squonk 45,592 #2 Posted October 27, 2014 On the deck are you sure the blades are hitting? The cross shaft stand bearings go bad a lot and the shaft where it presses into the bearing get worn down causing the shaft to move side to side. This causes the gears to bang and if it moves enough can cause it to jump time. Share this post Link to post Share on other sites
Sean Keys 57 #3 Posted October 27, 2014 It is the blades. They are chipping each others corners right off. Aren't they supposed to overlap? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #4 Posted October 27, 2014 The path of the blade tips should overlap but not the blades. Timed 90 degrees apart they can't hit each other. You can remove the bolts from the right bearing block that supports the cross shaft and loosen the same bolts on the left side. That will allow you to raise the shaft and gear on the right side away from the right spindle gear to get them timed. Garry Share this post Link to post Share on other sites
Pullstart 68,941 #5 Posted October 27, 2014 Is there a keyway somewhere that is supposed to keep them timed apart too? I've been having this problem this summer and have gone to the extent of hitting the cross-shaft nuts with my impact but they still find their way back out of time. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #6 Posted October 27, 2014 Is there a keyway somewhere that is supposed to keep them timed apart too? I've been having this problem this summer and have gone to the extent of hitting the cross-shaft nuts with my impact but they still find their way back out of time. Everything should be keyed or have a double-D hole in the blade. What is your deck model number or tractor model number and width of cut? That way we can dig up a parts list. Garry Share this post Link to post Share on other sites
Sean Keys 57 #7 Posted October 27, 2014 Deck appears to have a 33" cut, and is a rear discharge. I could not find a tag on it or any form of identification. I will post a pic of the tractors id tag here directly. Share this post Link to post Share on other sites
Sean Keys 57 #8 Posted October 27, 2014 Here is a pic of the tractors id tag. Unfortunately someone painted over it. Let's try that again..... Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #9 Posted October 27, 2014 Your tractor model number is written with a dash 1-3741. When you go to the attachment list they show deck models 5-2322 replaced by 5-2323. They also show 5-2362 but it is the same deck in a 36" width of cut and not 32" as Toro states. The parts lists are shared so easy mistake to make. 5-2322 ipl 1-3741 operator manual ipl and wiring The 16" blades #7908 and 7909 have been replaced by 8777 2-blade set from Toro The 18" blades #7906 and 7907 have been replaced by 8014 2-blade set from Toro Garry Share this post Link to post Share on other sites
Sean Keys 57 #10 Posted October 27, 2014 Thanks a bunch Garry, I think rebuilding the deck probably isn't a bad idea. I will have to get around to tearing it down and rebuilding it one of these days Share this post Link to post Share on other sites
Pullstart 68,941 #11 Posted October 28, 2014 looks like we're working on two different decks.. found my manual for deck 3262 I believe for the 502 model tractor. I see there's a woodruff key on the face gear that I suspect is sheared off. I'll just have to inspect to see what side needs attention but I think I need to pull the entire cross shaft assembly to get to that. Share this post Link to post Share on other sites
Sean Keys 57 #12 Posted October 28, 2014 Thanks, that's something that never crossed my mind. I will have to tear into it one of these days. Share this post Link to post Share on other sites
