jessejohn 0 #1 Posted October 21, 2014 Greetings all, I have a work horse LT-1100 that will only run with the choke on. Any suggestions? Share this post Link to post Share on other sites
oldredrider 2,554 #2 Posted October 21, 2014 The carburetor is DIRTY! Remove it from the engine and soak it in carb cleaner...does a world of good. Share this post Link to post Share on other sites
Geno 1,932 #3 Posted October 21, 2014 Most of the time that is it. Share this post Link to post Share on other sites
jessejohn 0 #4 Posted October 21, 2014 I noticed I little oil under my cylinder head when I moved it the other day. Any chance it could be the cylinder head gasket? The carburetor is DIRTY! Remove it from the engine and soak it in carb cleaner...does a world of good. I noticed I little oil under my cylinder head when I moved it the other day. Any chance it could be the cylinder head gasket? Share this post Link to post Share on other sites
Desko 687 #5 Posted October 22, 2014 Only if its OHV but in that model its a flat head unless someone changed the engine so no but it could be coming from the breather or the carb and leaking down and dripping from the head Share this post Link to post Share on other sites
jessejohn 0 #6 Posted October 22, 2014 Head is in the front of the engine on this model Share this post Link to post Share on other sites
Desko 687 #7 Posted October 22, 2014 Ok then its a flat head so id check the breather next Share this post Link to post Share on other sites
Eck 6 #8 Posted October 22, 2014 See my post (#3) here. It may be of some help. Share this post Link to post Share on other sites
Live4outdoors 151 #9 Posted October 23, 2014 Before you tear the carb off try the easy remedy, mix 50% marvel mystery oil to 50% gas and let it get to the carb and sit for a day or two and then try again, that will often loosen the dirt and gum and you don't even need to remove it. Share this post Link to post Share on other sites
