876wheelhorse 46 #1 Posted October 20, 2014 how do i get more rpm out of a kohler 10 hp? at wot it just dont seem like its revs very high.......i was told its only around 2800 id like around 3400 rpms Share this post Link to post Share on other sites
oaktown1987 82 #2 Posted October 20, 2014 3600 rpms is what it's suppose to be Sent from my iPhone using Tapatalk 1 Share this post Link to post Share on other sites
Fordiesel69 272 #3 Posted October 20, 2014 http://www.kohlerengines.com/onlinecatalog/serieslanding.htm?series=K-Series Gov needs to be adjusted. Share this post Link to post Share on other sites
876wheelhorse 46 #4 Posted October 20, 2014 ok how do i adjust gov there is a bolt where the cable goes do i move that over alittle ? and how? Share this post Link to post Share on other sites
Fordiesel69 272 #5 Posted October 20, 2014 K-series or Magnum? Share this post Link to post Share on other sites
pfrederi 20,915 #6 Posted October 20, 2014 If a K series. Share this post Link to post Share on other sites
Fordiesel69 272 #7 Posted October 20, 2014 If k-series, please do not mess with the gov shaft. Do everything else. Share this post Link to post Share on other sites
876wheelhorse 46 #8 Posted October 21, 2014 its a k series the arm goes all the way over to the stop and if i loosen that bolt what happens ? Share this post Link to post Share on other sites
Fordiesel69 272 #9 Posted October 21, 2014 If you loosen the bolt and are not familiar with engines, you can have a real mess getting it right again. You really can't feel what you are doing thru the pliers. Perform the adjustment per the manual on the cable / springs first. If you can't get it working, then maybe try the shaft. Share this post Link to post Share on other sites
