WHEEL HORSE 312-8 52 #1 Posted October 9, 2014 What size brand type? Share this post Link to post Share on other sites
CasualObserver 3,411 #2 Posted October 9, 2014 NO. The skinnier the tire, the better for snow. More surface area = more floatation... bad on snow. 5 Share this post Link to post Share on other sites
dandan111 31 #3 Posted October 9, 2014 ^true. Skinny is best in the snow. Share this post Link to post Share on other sites
WHEEL HORSE 312-8 52 #4 Posted October 9, 2014 Are 23-7.50-12 good with chains that's what I have for my 312 Share this post Link to post Share on other sites
dandan111 31 #5 Posted October 9, 2014 That should do it. Over in Conn. your going to need weight. /as much weight as you can find. Wheel weights and fill the tires. Washer fluid is what I used in my tires. Share this post Link to post Share on other sites
WHEEL HORSE 312-8 52 #6 Posted October 9, 2014 Fill tires?the tires I have on my 312 now r 12ply tires there so thick I don't need air in them Share this post Link to post Share on other sites
Rick_in_CT 156 #7 Posted October 9, 2014 Another down-side to having dual wheels when clearing snow is the extra width of the dual wheels can end up being wider than your snow clearing device (plow or blower). 3 Share this post Link to post Share on other sites
AJ_Thanatos 516 #8 Posted October 9, 2014 NO. The skinnier the tire, the better for snow. More surface area = more floatation... bad on snow. Jason nailed this one! 1 Share this post Link to post Share on other sites
WHEEL HORSE 312-8 52 #10 Posted October 9, 2014 I have 23-10.5-12 on my offroadingwheen horse will tat digging to shown good Snow Share this post Link to post Share on other sites
Ed Kennell 41,913 #11 Posted October 9, 2014 Fill tires?the tires I have on my 312 now r 12ply tires there so think I don't need air in them 12 ply.. no air required is no problem. You can still fill the tires with washer fluid for added weight. Filled tires are the best way to add weight, unless you have a heavy front mounted snow blower and need to decrease the weight on the front wheels to improve steering. Then I would go to a rear mounted weight box. Share this post Link to post Share on other sites
Kegler 68 #12 Posted October 10, 2014 Where do you find 12 ply's? What kind of tread pattern do they have? Share this post Link to post Share on other sites
WHEEL HORSE 312-8 52 #13 Posted October 11, 2014 I got them from a friend I'll put up a pic after or search on google Goodyear 12 ply tires Share this post Link to post Share on other sites
WHEEL HORSE 312-8 52 #14 Posted October 11, 2014 Go in gallery on here iits tractor with winch on back those r tires Go in gallery on here iits tractor with winch on back those r tires Share this post Link to post Share on other sites
Geno 1,929 #15 Posted October 11, 2014 Probably skid steer tires. Share this post Link to post Share on other sites
WHEEL HORSE 312-8 52 #16 Posted October 11, 2014 There from a exmark zero turn with 72" deck thing as huge Share this post Link to post Share on other sites
diamondred 63 #17 Posted October 14, 2014 (edited) Winter tires.... UTV tires 25x8x12 fit perfect. with weights... Edited October 14, 2014 by diamondred Share this post Link to post Share on other sites
WHEEL HORSE 312-8 52 #18 Posted October 14, 2014 Hell ya those r awesome Share this post Link to post Share on other sites
Kegler 68 #19 Posted October 15, 2014 Got a set very much like those with my 417H, Will have to take a closer look at them. Might decide to mount them. Share this post Link to post Share on other sites
flyovrcntry 115 #20 Posted October 15, 2014 You will wish you had chains when you come to packed snow or ice.The tire pattern makes very little difference in snow. Share this post Link to post Share on other sites
bmsgaffer 2,053 #21 Posted October 15, 2014 (edited) You will wish you had chains when you come to packed snow or ice.The tire pattern makes very little difference in snow. I disagree (with half). Tread pattern makes a HUGE difference in snow. It makes NO difference on ice. Much of the time, in my climate anyway, if you have good deep groove/knob tires you can get down to the concrete/asphalt which will give you traction. Then, if there is enough solar energy (or you use snow melt) you will melt it all off and have good grip again for the next go around.... If there is a layer of ice under it though (either from the weather or from not clearing it off well enough before), forget it. By dad and I plowed a 150' drive for 20+ years with a C-105 and ag tires. No chains or weights. (It did get hairy sometimes though). I think weight is your biggest asset, and if you deal with ice or hard pack you need chains (or if you only have shallow turf tires available) Edited October 15, 2014 by bmsgaffer 3 Share this post Link to post Share on other sites
WHEEL HORSE 312-8 52 #22 Posted October 16, 2014 My 12 ply r horrible for snow the tread is sunk down in tire not raised like lawn tires Share this post Link to post Share on other sites
