dclarke 4,098 #1 Posted September 28, 2014 A friend wants me to restore his mother's tricycle and I know next to nothing about where to look for information or parts for this old thing. Anybody into rebuilding these things or know anything that might help? 1 Share this post Link to post Share on other sites
stevasaurus 23,448 #2 Posted September 28, 2014 (edited) WOW...I wonder if American Pickers or the other show that does custom rebuilds in California may have a Web Site that could point you in the right direction. Cool job Denny...good luck mate. Doesn't hurt to look and maybe ask. Antiques Roadshow has a Website also with a cast of characters that may be able to help. Edited September 28, 2014 by stevasaurus 1 Share this post Link to post Share on other sites
AMC RULES 37,226 #3 Posted September 28, 2014 There are tricycle specific forums out there... might find some help there, good luck with it Denny. 2 Share this post Link to post Share on other sites
Brrly1 1,146 #4 Posted September 28, 2014 American Restoration 1 Share this post Link to post Share on other sites
dclarke 4,098 #5 Posted September 28, 2014 Good ideas, guys. I knew this was the place to get started. Share this post Link to post Share on other sites
JimD 3,347 #6 Posted September 28, 2014 Denny, here are a couple links.. http://www.tricyclefetish.com/tricycle-parts-c-59.html http://pedalcarbooks.com/Pedal%20Car%20Parts.htm 2 Share this post Link to post Share on other sites
dclarke 4,098 #7 Posted September 29, 2014 Thanks, Jim! 1 Share this post Link to post Share on other sites
64s 83 #8 Posted September 29, 2014 American Restoration And $6500.00 3 Share this post Link to post Share on other sites
Brrly1 1,146 #9 Posted October 5, 2014 I know they are pretty pricey but, I really don't think the repair to the tricycle would be Quite that much.I still think it's a good show to watch along with several others on Discovery or even the History channel works for me 1 Share this post Link to post Share on other sites
Coadster32 793 #10 Posted October 6, 2014 Cool find. I'm sure you'll do it justice. Share this post Link to post Share on other sites
GlenPettit 1,718 #11 Posted October 6, 2014 (edited) Denny: Let me know the gauge or OD of those handlebars. I'm in the process of making some 3" long by 1/2" black hand grips, they are the same ones used on the Bolens 'Garden Master' riding tractors from the 40's, but they were originally used on small tricycles, like your picture. The Bolens restorers just can't find them anywhere, all the original ones have broken down/apart. I'm going from some old photos I blew up to try and reconstruct them to match the original Bolens ones. Will try and add a photo asap, if they'll fit, I'ld be glad to send you a pair as a gift for your restoration. Glen Either of these pairs should work and be a match. FYI: I'm in the process of make them now, the home-made jig on the left lets me control the depth, straightness and centering of the core (where metal handle is it slips on to), the molds are in the center and the grey rigid casing for support during casting. The mold & core are soft Silicone and grips will be epoxy rubber. I'm still in the process of sanding and carving, and will probably have to make 3-4 generations of casts before they are reasonably correct to use as a "Master Mother", sure wish I had a lathe for these. Will probably be December before they are ready. I'm still having fun doing (or trying to do) 'what can't be done' in making restoration parts. GP Edited October 6, 2014 by GlenPettit 2 Share this post Link to post Share on other sites
dclarke 4,098 #12 Posted October 7, 2014 Denny: Let me know the gauge or OD of those handlebars. I'm in the process of making some 3" long by 1/2" black hand grips, they are the same ones used on the Bolens 'Garden Master' riding tractors from the 40's, but they were originally used on small tricycles, like your picture. The Bolens restorers just can't find them anywhere, all the original ones have broken down/apart. I'm going from some old photos I blew up to try and reconstruct them to match the original Bolens ones. Will try and add a photo asap, if they'll fit, I'ld be glad to send you a pair as a gift for your restoration. Glen Thanks for the offer, Glen. These handle bars are 3/4" dia. so I'm not sure your grips would fit. They would certainly add a nice touch to this project though, you do amazing work! Share this post Link to post Share on other sites
dclarke 4,098 #13 Posted October 29, 2014 (edited) I got the handlebars and wheels painted then sent the wheels to "Rideable Bicycle Replicas" in California to have the solid tires installed. These tires are cut to length, the rubber has a hole in it that a wire is inserted into. It's then installed, the rubber is pulled back and the wire is either twisted tight or pulled tight and brazed to hold the tire on. It took a lot of searching to find someone to do this, I'm glad I had this done by someone that knows what he's doing rather than try it myself. Edited October 29, 2014 by dclarke 7 Share this post Link to post Share on other sites
AMC RULES 37,226 #14 Posted October 29, 2014 Humm...who knew? Share this post Link to post Share on other sites
Coadster32 793 #15 Posted October 30, 2014 They look great!! 1 Share this post Link to post Share on other sites
Geno 1,930 #16 Posted October 30, 2014 It will be like brand new! 1 Share this post Link to post Share on other sites
GlenPettit 1,718 #17 Posted October 30, 2014 (edited) Denny: If you have not found a pair of Grips yet, I can make those tricycle grips with a 3/4" core, and will be. Learned that that same style was also available in 5/8" as well as 1/2", but there is room for a larger 3/4" core, so I'll be making some. They were the style of tricycle grips used in the 30's & 40's, and again, they were also used on one & two wheel garden tractors way back then (also called 'Mules'), and that's why I started to make grips, for restorations, since the original grips are all gone. PM me your home address if you want a pair, as a gift, if you post a finished photo when all restored. The originals were black, but I can make them in any color (red, pink, . . . but not Green). If people wanted to add colored stringers, they just drilled their own hole in the grip for it. Glen Edited October 30, 2014 by GlenPettit 1 Share this post Link to post Share on other sites
dclarke 4,098 #18 Posted October 30, 2014 Thanks, Glen. I'd love to have a set of Red grips for this. P. M. Sent. You're the Best! Share this post Link to post Share on other sites
Zeek 2,298 #19 Posted October 30, 2014 That looks cool. I like anything vintage that is restored 1 Share this post Link to post Share on other sites
dclarke 4,098 #20 Posted December 24, 2014 I finished this tricycle just in time for Christmas, I'm really pleased with the way it turned out. It belongs to a friend's mother, she rode it as a little girl. I'm sure she'll be surprised when she see's it.... Many thanks to "Vinylguy" Terry Dennis for making the custom decal and to Glen Pettit for making the custom hand grips in the color and size I needed. Both the decal and the grips made this project turn out so much nicer than it would have without those finishing touches and both of these guys did this free of charge. I can't thank them enough! 14 Share this post Link to post Share on other sites
Martin 2,133 #21 Posted December 24, 2014 Turned out really nice Denny. Kent did an old tricycle a couple years ago. I painted it at work and he put it all together. It had the solid rubber tires and similar handgrips. Jeanine found some replacement grips online but they were expensive and not exactly like the originals. Kent sold it to one of Jeanine's friends who had a small grand daughter. Made a nice Christmas present. I will have to see if I can dig out some pics. Sent from my iPhone using Tapatalk 1 Share this post Link to post Share on other sites
stevasaurus 23,448 #22 Posted December 24, 2014 Denny, that came out "eye popping" sharp. It is great to see memories like that brought back to life. WOW !!! 1 Share this post Link to post Share on other sites
JimD 3,347 #23 Posted December 24, 2014 Beautiful! 1 Share this post Link to post Share on other sites
AMC RULES 37,226 #24 Posted December 24, 2014 Really did turn out really nice Denny. 1 Share this post Link to post Share on other sites
ronwh 190 #25 Posted December 24, 2014 Denny, You do great work, I am sure she will love it. Ron 1 Share this post Link to post Share on other sites
