snarfbatt 1 #1 Posted September 25, 2014 Hello everyone; I have a 520H that blew the flat idler (on the attach a matic), ok just find a new one and replace. Well easy said not easy to find. Local dealer said $130 per pulley Ouch. Check on line and ended up at Jacks small engine. Ok $66 each so I ordered. They came in today and the flat idler looks right and is the blown one the other one they sent looks to be main deck pulley and will have to be sent back. My question is how to you the threaded stud off to get to the smaller shaft? That stud had a large threaded end (1 1/8 in) nut and holds the guard on. Got the nut off but now can't see a snap ring or key, and the pulley shaft appears smaller. Thanks ahead of answers as I know someone here has the answer. I have check here before but never joined. Share this post Link to post Share on other sites
daveoman1966 3,882 #2 Posted September 25, 2014 The pulley shaft is 3/4" dia on that mule drive. The sequence should be: Nut...shield...spacer...flat idler...spacer...V pulley. contact me at: daveoman@windstream.net (just clik that link) 1 Share this post Link to post Share on other sites
Geno 1,931 #3 Posted September 26, 2014 Hello and Looks like Dave's got you took care of. Share this post Link to post Share on other sites
snarfbatt 1 #4 Posted September 26, 2014 Wow thanks. Looks like the flat idler goes back also. The one Jacks sent me is a 5/8 size. First post with question answer in a short time. Looks like I found the right place. I am home I will post the story and pictures of my 520H soon. Share this post Link to post Share on other sites
snarfbatt 1 #5 Posted September 26, 2014 You would think a online retailer, that you call and give all the model numbers of the tractor and the deck would get it right. But Jack's got it wrong. Other places give Jacks high props. I am not so sure. WH give me places to get parts? Share this post Link to post Share on other sites
KyBlue 655 #6 Posted September 27, 2014 Are you sure that you have right numbers ?? You'll need the numbers for the Mower Deck not the tractor since they came w/o the deck ... Dave can probably set you up with a used one ... Share this post Link to post Share on other sites
