scotty 252 #1 Posted September 22, 2014 now i am completly stumped maybe im just being dumb but i dont see a steering gear grease fitting on my 520. Share this post Link to post Share on other sites
cleat 8,984 #2 Posted September 22, 2014 Gear reduction steering has 2 fittings, one you access from the top between the steering column gear and gear closer to engine. The other one you access from underneath basically right below where you just greased on the small block holding the lower gear. Also do not forget the tie rod ends, spindles, front axle pivot, and wheel bearings. Standard steering models just have the fitting you access from above, the spindles, front axle pivot, and wheel bearings. Cleat 2 Share this post Link to post Share on other sites
