scotty 252 #1 Posted September 1, 2014 what are the 4.00-8 tri rib tires there alot cheaper. my b80 has 16-6.50x8 front tires. is there much difference in size or wont they even mount to the rim? Share this post Link to post Share on other sites
Kelly 1,033 #2 Posted September 1, 2014 Depending on the year of your B-80 as to if it has wide or narrow front rims, if narrow about 3 3/4" wide inside the beads, the small tri ribs are a great fit, if you have the wide rims about 5 3/8"wide inside the beads, they will not fit very well, but most B-80's I've seen have the narrow rims Share this post Link to post Share on other sites
scotty 252 #3 Posted September 1, 2014 (edited) my b80 is a 1974. will using these smaller tri ribs would i still be able to mow?i dont want it to cut grass unevenly. thanks. Edited September 1, 2014 by scotty Share this post Link to post Share on other sites
Racinbob 12,267 #4 Posted September 1, 2014 The B series are kinda all over the place. I know the 76 and 77 had 16-6.50x8's and I'm pretty sure the 74 and 75 did too which seems to be supported by you having that size. Share this post Link to post Share on other sites
Kelly 1,033 #5 Posted September 1, 2014 The early C's and B's had the 16x6.5 tires but still used the narrow rims like the 60's, the later 70's machines used the same tire but on a wider rim 1 Share this post Link to post Share on other sites
scotty 252 #6 Posted September 1, 2014 would anyone happen to have a picture of what they would look like by any chance? Share this post Link to post Share on other sites
Kelly 1,033 #7 Posted September 1, 2014 of what ?? tires or rims ?? Share this post Link to post Share on other sites
Martin 2,133 #8 Posted September 1, 2014 heres a few pics for you..... deestone 4.00 x 8 on early rims (3.75 wide) 16 x 6.50-8 on early rims c series beige colored (3.75 wide) and 16 x 6.50-8 on later 5.38" wide rims silver colored 1 Share this post Link to post Share on other sites
scotty 252 #9 Posted September 1, 2014 Pictures with the tire on the rim just like martin. Is there much of a height difference in 16x6.50-8 and 4.00-8? Thanks those were just what I was looking for! Share this post Link to post Share on other sites
Martin 2,133 #10 Posted September 1, 2014 16 x 6.50-8 on early rims and 4.00-8 deestone d401 on early rims...... 1 Share this post Link to post Share on other sites
scotty 252 #11 Posted September 2, 2014 i ordered up a set of 4.00-8 tri ribs! thanks for the help guys! Share this post Link to post Share on other sites
