Johnpaul 0 #1 Posted August 24, 2014 (edited) What the procedure on fixing rear axle gear fluid from leaking? Replace axle seals? (WH 308-8 with Uni drive transmission. Edited August 24, 2014 by Johnpaul Share this post Link to post Share on other sites
Racinbob 12,798 #2 Posted August 24, 2014 Yup. It can be done without opening the transmission. Share this post Link to post Share on other sites
Johnpaul 0 #3 Posted August 24, 2014 Thanks for your reply, is there a procedure for how to replace axle seals? Please forward. Share this post Link to post Share on other sites
AMC RULES 37,254 #4 Posted August 24, 2014 Depends on where the leak is coming from. Share this post Link to post Share on other sites
Racinbob 12,798 #5 Posted August 24, 2014 (edited) From your first post it sounds to me like it's leaking at the axle seals??? There's tons of help here if that, or any other issue you may have. You just need to confirm what's leaking. Edited August 24, 2014 by Racinbob Share this post Link to post Share on other sites
Johnpaul 0 #6 Posted August 24, 2014 Correct, it's leaking from the rear axle seals. How do I replace the rear axle seals? Share this post Link to post Share on other sites
Racinbob 12,798 #7 Posted August 24, 2014 (edited) The hardest part might be getting the hubs off. Once you do that just carefully pick the old seals out. Before you install the new seals make sure your axles are free of nicks and burrs. Pay special attention to the hub key slot. You don't want to damage the new rubber. Lightly oil the axle and slide the new seal in place and, the way I do it, slip a large washer over the axle and tap, don't beat, the seal in place with a short piece of pipe. PVC works fine for me. The seal should be flush and the washer will 'tell' you when it is. Edited August 24, 2014 by Racinbob 1 Share this post Link to post Share on other sites
Johnpaul 0 #8 Posted August 24, 2014 Thank you very much Racinbob, I will follow your instructions, I appreciate your assistance. Share this post Link to post Share on other sites
Racinbob 12,798 #9 Posted August 24, 2014 You're welcome John. I'll add that you should check the bearings for excessive play (side to side). I'm betting that won't be a problem though. Share this post Link to post Share on other sites
Ed Kennell 44,986 #10 Posted August 24, 2014 Like Bob says , remove the hubs. They can be the challenge. Remove all the set screws . Make sure there are not double stacked screws. Soak the hubs and fill the set screw holes with PB blaster. I use a home made puller with 5 -3/8 X 5" bolts and sockets as spacers to pull the hubs. BE careful..they are cast and they will break. Share this post Link to post Share on other sites
Johnpaul 0 #11 Posted August 24, 2014 Will do. I will check the bearings for excessive play. Thanks for your advice. This is a great website! Share this post Link to post Share on other sites
Johnpaul 0 #12 Posted August 24, 2014 Ok, thanks for your advice ekennell. Share this post Link to post Share on other sites
can whlvr 994 #13 Posted August 24, 2014 heres a pic of a homemade puller,an angle ioron and a large bolt and nut welded to the angle and five holes drilled to match hub Share this post Link to post Share on other sites
Johnpaul 0 #14 Posted August 24, 2014 Ok, thank you for your support. Share this post Link to post Share on other sites
Ed Kennell 44,986 #15 Posted August 24, 2014 After you get the hubs and the old seals off, you should clean the hub bores and the axles with solvent and polish with scotch brite. Then fit the hubs back on by hand. Do not beat them back on. Paint the area around the keyway with a black felt marker and slide the hub on till it stops. Pull it back off and the mark on the painted area will show you where to file off the high spot on the axle. The axle is usually bulged up on the back side of the keyway where the axle is driving the wheel forward. File only the high spot, then repaint and refit till the hub slides on. Do it slowly and remove as little metal as possible. It may require 10 or 20 trial fits to get it to slide on. The new seal will now also slide on easily. Share this post Link to post Share on other sites
Johnpaul 0 #16 Posted August 24, 2014 Ok, I can do that, thanks for all the details, very helpful. Share this post Link to post Share on other sites
