608KEB
Starter stays engaged
608KEB
I went to start my 75 C-120 and it was dead. I thought the battery was dead. I put a different battery in. When I was hooking up the positive, the tractor started turning over. It ran fine last time I used it. Suggestions? :scratchead:
Racinbob
If nothing else was changed it sounds like you have a bad solenoid. Pretty odd though. Maybe something shorted and the power is constantly on at the S terminal? I would pull the cable off on the starter to troubleshoot it.
Edited by Racinbob
squonk
Pull the small wire off the solenoid to see if it has power with the key off. If it does go to the switch and check the wires. A mouse could have gotten into it and chewed through some of the wires also.
608KEB
I cleaned the connections to the solenoid. Cleaned the positive battery cable and the small wire too. It started right up! I'm confused as to what the problem was.
608KEB
Another problem with the C-120. The ammeter gauge won't move. I noticed one of the wires running to it got really hot. Also I had to shake one of the wires to the rectifier to get it to start. Do I need a new ammeter gauage? I'll clean the contacts to both pieces.
Save Old Iron
If you disassemble the starter relay
you will most likely find the contacts severly pitted
pitted contacts may temporarily "weld" together.
Geno
Hot connections are bad connections most of the time.  :)
608KEB
I have no spark. Lights don't work, won't turn over nothing. I changed the amp meter, changed the starter relay. changed the battery. Cleaned and checked connections. Still won't turn over. Turned over last night. I'm confused :laughing-rofl: Does it matter which way the starter relay is hooked up + or -. What do I have to bypass to see if it will turn over. Also the wire that was getting hot before was the one that was running from the amp meter to the starter relay. I gotta run for now. But hopefully I can look at it again tonight.
Edited by 608KEB
gwest_ca
If you are going to leave this unattended I would disconnect the negative battery cable and isolate it. Hate to see something go wrong when you are not with it.
Garry
608KEB
Found the problem, The replacement amp meter gauge also had a loose connection. It's good to go now! :woohoo:
Geno
One thing I've learned over the years, new does not mean good.  Bad parts are the main reason I semi-retired last year.  When you do this for a living it stinks to do the same job 2 or 3 times before it even leaves the shop and get paid for doing it once.    :eusa-doh:
608KEB
I am really stumped. I went to start the C-120 and nothing. The battery is good. I disconnected the positive lead. I'm charging battery now. Any suggestions? :no: I also started it 3 times last night. Maybe an hour after cutting grass.
Edited by 608KEB
Geno
Recheck what you've already checked, especially the amp gauge connections.    :)
608KEB
I had a senior moment at 50. It works fine. Thanks Geno. :happy-jumpeveryone:
Geno
It does say "Senior Member" above your avatar, you should change that.   :laughing-rolling:
  • Similar Content
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • BrianKoch
      By BrianKoch
      Hello gentleman,
      Problem: will not crank on its own, will crank with jump box—but still not fire
      Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
      I have my test light out and am probing around.
      There is no power at ignition/magneto wire or the ignition/starter wire
      There is power everywhere else
    • Jeff-C175
      By Jeff-C175
      Detailed wiring from the Demystification Guide #492-4509
      4 pages 1.4MB Color
      p7-67 to p7-70
      Onan powered
      1989 416-8 model 31-16O801
    • trident
      By trident
      Need some help. My 800 Special has an electric PTO. It is not working. Checked Ohms - nothing. My questions are 1) how does the PTO come off and 2) can they be rebuilt? I took the bolt out that I thought holds it on but no luck. Must be something more?
    • grasscuts
      By grasscuts
      Hi, here's what happened. I changed out 9 pin moles plug...had issues tracter quit running and changed the plugs while I was at it....got plugs from auto store cross reference to ngk they said it was the same heat range and I check electrod  length with calipers ,same...tracter started right up and ran great for about 10 min. And started back firing and quit.....going to check it out tonite anybody have an idea?
