Tim
PTO disengages on mower
Tim
what would cause this just pops out when mowing
could something be worn
it is a 314-8
Edited by Tim
boovuc
Couple things come to mind. My 416 would pop out once and a while. The bushing on he PTO lever on my 416 is cracked and has a lot of play on it. Also, the PTO itself needed adjusted. (Too loose).
Look at that bushing where the PTO lever goes through the tin. Check for play. Also make sure the PTO shaft has some moderate resistance when engaging the PTO clutch. If not, adjust until you have resistance three-quarters of the way pushed forward all the way into the locked position.
can whlvr
check the spring on the lever
