biggin 37 #1 Posted August 14, 2014 (edited) Does anyone use the lift assist spring with a hydro lift? I know I don't need it, just curious if anyone used it. 02' DL never finished Edited August 14, 2014 by biggin Share this post Link to post Share on other sites
yngliver 4 #2 Posted August 14, 2014 I don't use the spring but do you mind if I ask you a question? I just got a blower to hook to my 312-h. I have noticed then when I fully lower it the flag detatches from the lifting rod. I wasn't sure if there should be something like a spring holding them together or not. Any ideas? Share this post Link to post Share on other sites
biggin 37 #3 Posted August 14, 2014 (edited) You don't need the spring but it'll make lifting it much easier. Sounds like you need a spacer on the end of the lift bar where the flag goes in, not uncommon from what I hear. Here's a pic of the lift assist spring. 02' DL never finished Edited August 14, 2014 by biggin Share this post Link to post Share on other sites
Geno 1,930 #4 Posted August 14, 2014 Nothing holds them together. You may have the flag in the wrong lift arm hole. Does anyone use the lift assist spring with a hydro lift? I know I don't need it, just curious if anyone used it. 02' DL never finished I don't use one. Some flags have a place for a spring hookup and some don't. Share this post Link to post Share on other sites
biggin 37 #5 Posted August 14, 2014 Thanks, wasn't sure if it would help the wear and tear on the hydro. 02' DL never finished Share this post Link to post Share on other sites
Geno 1,930 #6 Posted August 14, 2014 Thanks, wasn't sure if it would help the wear and tear on the hydro. 02' DL never finished The only real wear issue I have seen with the blowers is the front bearings and wheels. I wouldn't tote that thing around no more than necessary. I bought a c145 that had the blower mounted to it for many years and both front wheels had a split in the hub. Share this post Link to post Share on other sites
biggin 37 #7 Posted August 14, 2014 Ok, good advice, was only planning to have it on during the winter 02' DL never finished Share this post Link to post Share on other sites
