Nick P. 20 #1 Posted August 7, 2014 Seeking advice on how to replace twin belts on a 1965 twin blade 36" deck. Does the pulley shaft need to disconnect to remove/ replace the v belts? Thanks, Nick Share this post Link to post Share on other sites
squonk 43,717 #3 Posted August 7, 2014 (edited) Get lots of rags!! Yes you have to un - bolt the cross shaft bearing stands to slip the belts around the right gear and bearing stand Edited August 7, 2014 by squonk Share this post Link to post Share on other sites
Nick P. 20 #4 Posted August 7, 2014 I have a bunch of old T Shirts that can be donated to the operation . Thanks Pardner Share this post Link to post Share on other sites
SousaKerry 503 #5 Posted August 7, 2014 I would suggest studying up on your french. You will use lots of it during the job when you realize that you missed one little part after the 4th time putting it together. Wheel horse designed a lot of wonderful things, those decks were not one of them. 1 Share this post Link to post Share on other sites
slammer302 2,156 #6 Posted August 7, 2014 Don't forget to make sure the blades are timed correctly while you have it apart 1 Share this post Link to post Share on other sites
Nick P. 20 #7 Posted August 8, 2014 Okay now I am rethinking --the reason I want to replace the belts is the blade and shaft rotation slows or stops when I am cutting tall 3"-4" grass. At full throttle I stop and raise the deck lever out of the tall grass to regain shaft spin momentum R. P. M. 's then resume at slow crawl. Maybe I check the other drive belts first before messing with the twin belts...? Share this post Link to post Share on other sites
slammer302 2,156 #8 Posted August 8, 2014 The belts may just need adjusted Share this post Link to post Share on other sites
Nick P. 20 #9 Posted August 8, 2014 Thanks for the idea. Adjusting belts on the deck: do you slide the engine forward or is there some other method? Share this post Link to post Share on other sites
Racinbob 11,917 #10 Posted August 8, 2014 The rod ends on the assembly hanger are threaded. Adjust them to the correct tension and lock in place with the jam nuts. The 'ball' joints at the opposite end on the cross rod get worn and sloppy, especially the left side. Share this post Link to post Share on other sites
Racinbob 11,917 #11 Posted August 8, 2014 (edited) Sorry, double post. Edited August 8, 2014 by Racinbob Share this post Link to post Share on other sites
Nick P. 20 #12 Posted August 9, 2014 Perfect description, I see it now in the parts diagram. That bugger looks like it is hard to get access to - I will give it a try and hope that I can get access without needing to disconnect the deck unit. Share this post Link to post Share on other sites
Texas Todd 1,025 #13 Posted March 28, 2017 Can someone tell me if this deck, the RM-364 will fit work on a 856? It looks like the 856 came with RM-366 or 367. Thanks! Share this post Link to post Share on other sites
evanloock 236 #14 Posted March 28, 2017 Yes it will work. Share this post Link to post Share on other sites
Texas Todd 1,025 #15 Posted March 28, 2017 Awesome. Thank you! Share this post Link to post Share on other sites
stevasaurus 23,274 #16 Posted March 29, 2017 @Texas Todd RM-364 = rear mower 36" 1964. RM-367 = rear mower 36" 1967 They also fit on the 1962s...502, 552, 702...1963s...1964s Share this post Link to post Share on other sites
Texas Todd 1,025 #17 Posted March 29, 2017 1 hour ago, stevasaurus said: @Texas Todd RM-364 = rear mower 36" 1964. RM-367 = rear mower 36" 1967 They also fit on the 1962s...502, 552, 702...1963s...1964s Roger that. I just gotta go get it! Thanks! Share this post Link to post Share on other sites
mikeeyre74 289 #18 Posted September 20, 2017 On 8/8/2014 at 9:40 AM, Racinbob said: The rod ends on the assembly hanger are threaded. Adjust them to the correct tension and lock in place with the jam nuts. The 'ball' joints at the opposite end on the cross rod get worn and sloppy, especially the left side. Is there a repair for this? Came across this'd thread while researching on my two that I just acquired... gonna get one ready for my 753 for next year. The ball and socket arrangement seems weird? Can it be repaired,or do you just need to find better stuff to start with? Share this post Link to post Share on other sites
Racinbob 11,917 #19 Posted September 20, 2017 That's definitely a weak spot on these decks. You can peen them a little to snug them up but it won't last long. There's a couple better fixes I've tossed around but I no longer have one of those decks to play with. I also mentioned it to Lowell a couple years ago at the big show since he comes up with a lot of nice parts that are better than original. Share this post Link to post Share on other sites
