Butch 194 #1 Posted August 1, 2014 My C175 use to start very easily on the first crank. It has gone from that to taking a lot of cranking to start. Maybe around 15 tries. There was nothing in between. From easy to hard. The oil, filters and plugs have 40 hours on them. Share this post Link to post Share on other sites
305 380 #2 Posted August 1, 2014 plugs can go bad , what brand are they? i'd try new ones and check the spark Share this post Link to post Share on other sites
T McCool 287 #3 Posted August 1, 2014 Clean the carb, filter, could be a clogged fuel filter..etc. good idea to check the spark though. Share this post Link to post Share on other sites
stevasaurus 23,521 #4 Posted August 1, 2014 Butch...if you have points in that engine...check the gap (.020) this controls the timing. In an older engine (many hours), I like to try the (.018) gap. Above is the link for the engine manual. If you have spark and the points look good, it is a fuel problem. Unless it is a compression issue. How does it run after it starts? Share this post Link to post Share on other sites
Butch 194 #5 Posted August 1, 2014 I'll try all of the above and I'll check the gap. Thanks guys! 1 Share this post Link to post Share on other sites
953 nut 63,371 #6 Posted August 1, 2014 Another thing to lok at would be the fuel pump, it has check valves in it and if they are not working 100 percent the fuel can leak down in between uses. After it has been sitting a few days crack the fitting at the carb and see if fuel cones out right away or has a long delay. Hope this helps. 1 Share this post Link to post Share on other sites
Butch 194 #7 Posted August 2, 2014 Another thing to lok at would be the fuel pump, it has check valves in it and if they are not working 100 percent the fuel can leak down in between uses. After it has been sitting a few days crack the fitting at the carb and see if fuel cones out right away or has a long delay. Hope this helps. When I bought the tractor the fuel pump leaked and that was the reason it was hard to start. I wondered if it was fuel pump related again. Thanks! Share this post Link to post Share on other sites
AMC RULES 37,251 #8 Posted August 2, 2014 Wonder...does it sit for a long time in between use? Store it under cover or outside in the weather? Share this post Link to post Share on other sites
Butch 194 #9 Posted August 2, 2014 Wonder...does it sit for a long time in between use? Store it under cover or outside in the weather? No, it's stored inside. May car and truck are outside but the tractors are inside. I wouldn't say they sit a long time between starts. And last winter when we got our first snow it probably was at least 3 months that it sat and it fired right up. My C-85, hit the ignition and it fires right up. Thanks. Share this post Link to post Share on other sites
Butch 194 #10 Posted September 14, 2014 Sorry it's taken so long to get back to you guys. Everything checked out ok. All of a sudden it began starting as normal. Now I'm baffled. Maybe a speck of sand in the carb that is now gone? It fires right up again. Everything is perfect with it. Share this post Link to post Share on other sites
