silversolder429
rock shaft ,rear axle bracket
silversolder429
what rock shaft , and rear axle bracket for tiller will fit on a C 175 , example will stuff from a C 120 work , or what other models thanks .
tbarnhart
As far as the axle bracket, It depends on the tiller, not the tractor. As you showed in your other thread, your tiller is a newer one that would take the bracket that bolts under the axle and does not contain an idler pullley. As for the rockshaft, I believe the width was different on several models, with the later ones being narrower than the early ones. The early C-120 tractors did not use a rockshaft and the 76-77 models used the wide rockshaft. I think your c-175 would take the newer rockshaft.
