Hemi8816 0 #1 Posted July 24, 2014 Does anyone know the length of the plow frame for a 79355 plow used on the 5xi series ? Share this post Link to post Share on other sites
doc724 927 #2 Posted July 24, 2014 Tell me where you want the dimension measured (for example from blade pivot hole to the hitch mounting location) and I will go out to the shed and measure mine Share this post Link to post Share on other sites
Hemi8816 0 #3 Posted July 25, 2014 Thanks for the reply. Looking for the length of the plow frame itself from the large bolt that holds the blade on, to the end with the bar that fits into the rear attach bracket mounted to the axle. Trying to see if I can modify an older plow that fits a C series or a 300, 400 series. I believe I need to make the plow frame longer but do not know how much. I have several older plows but cannot seem to find any attachments in my area for the 5xi series. Any help would be appreciated. Share this post Link to post Share on other sites
doc724 927 #4 Posted July 26, 2014 It is 70 inches (center of the bolt to center of the attachment bar). For reference, the standard C-series plow is 63 inches. Width between the channels at the back is the same as the C-series plow. Also note, because the 5xi plow is long, Toro added a ring to the plow near the front under the front tach-a-matic to accept a retainer which snaps into the front tach-a-matic. Go to Partstree.com and you can see a pix of it. The purpose is to prevent the frame from moving sideways when plowing at an angle when you hit a snow bank. On the smaller machines, the plow was shorter and the machines were only 600 pounds so they slid when you hit the snow bank. Try this on a 5xi and you will bend something. Good luck. Share this post Link to post Share on other sites
RMCIII 840 #5 Posted July 26, 2014 Hemi - one other item to point out. You may have already figured this out, the attach-a-matics on the "XI" are larger than that of the other lines of WH. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,463 #6 Posted July 26, 2014 The sway control was a retrofit for early dozer blades Garry Share this post Link to post Share on other sites
Hemi8816 0 #7 Posted July 27, 2014 Thank you all for the input and help. Ed Share this post Link to post Share on other sites
