horse75 0 #1 Posted July 14, 2014 I have a model 312A that requires sae20 motor oil for the transmission. I cannot find sae20 oil. What can i use as a replacement oil or where can i find sae20 oil? Share this post Link to post Share on other sites
rmaynard 16,885 #2 Posted July 14, 2014 (edited) According to the lubrication chart that came out in 1998, the recommended oil for your transmission is Gearcase SAE 10W-30 or 10W-40 engine oil. http://www.wheelhorseforum.com/files/file/488-chart-tractor-1956-1999-lubrication-recommendations-drive-belt-mower-blades-492-0392pdf/ Edited July 14, 2014 by rmaynard Share this post Link to post Share on other sites
shallowwatersailor 3,220 #3 Posted July 14, 2014 Some Tractor Supply stores carry 20W in gallon jugs. Later Lubrication charts recommend 30W for the transmission which is the plastic reservoir. The transaxle use 10W-30 motor oil and is checked with the dipstick. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,012 #4 Posted July 14, 2014 The original 20 weight was changed to 30 weight in 1991 and 40 weight in hot climates I would go with the 10-30 or 10-40 since that is the latest recommendation. Garry Share this post Link to post Share on other sites
shallowwatersailor 3,220 #5 Posted July 14, 2014 The 312A has two different requirements. One for the transmission and the other for the transaxle. Share this post Link to post Share on other sites
GeoPeg 0 #6 Posted July 20, 2014 I have a similar scenario to that of horse75, except mine is a 314A - My original operators manual states "Hydrostatic transmission requires a straight SAE 20 weight premium quality motor oil API service classification SC, SD, SE, or SF. Transaxle requires 10W30 or 10W-40 premium quality motor oil." I too have found 20 wt impossible to buy except on-line, in case quantities. The only question I would ask is what's the risk using 10W-30? Will the higher viscosity at operating temperatures potentially cause any seal failures? Just for grins, I have the original sales receipt from 1985, my dad paid $2999 for the tractor and $555 for the 42" SD deck. Wish I could buy a new one of this quality at that price today! Share this post Link to post Share on other sites
