stevebo-(Moderator) 8,604 #1 Posted July 8, 2014 All- I am getting ready to repaint one of my old vintage metal boat gas tanks. I remember several years ago I repainted one and after I spilled a little bit of gas on the paint it peeled really bad. Can you tell me what type of paint I can use that will not peel if paint gets on it?? Thanks Share this post Link to post Share on other sites
roscoemi 245 #2 Posted July 8, 2014 Paint that will not peel paint? My rustoleum on the tractors has not peeled if it is fully cured when gas gets on it. Share this post Link to post Share on other sites
SALTYWRIGHT 861 #3 Posted July 8, 2014 TEMPO THAT MAKES THE TANK USED TO SELL PAINT FOR THE TANKS. TRY A MARINE STORE. I WILL CHECK TOMMOROW AT OUR MARINA. Share this post Link to post Share on other sites
Ken B 3,202 #4 Posted July 8, 2014 The vast majority of antique outboarder's don't repaint their tanks due to the fact that they see so much fuel dumped on them that they wind up peeling. I have used the guy at NY Marine's paint and it worked excellent. I've also used Duplicolor engine paints and their engine paint clear coat. You must follow the directions and ya gotta let it cure. A lot of the guys that have "show boats" have "show" tanks that see no gas, they use an unpainted tank when they plan to use the boat... I haven't tried the Rustoleum Farm & Implement IH red yet but Roscoe is right, I've spilled gas on it before and if its cured it hasn't peeled. I'd use a self etching primer for sure. What paint did you use a few yrs. ago that peeled? Share this post Link to post Share on other sites
VinsRJ 723 #5 Posted July 8, 2014 I've also used Duplicolor engine paints and their engine paint clear coat. You must follow the directions and ya gotta let it cure. I find the Duplicolor Engine paints to be durable also. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #6 Posted July 8, 2014 Honestly it was more like 20 years ago and I have no idea what it was. I think I may try the duplicolor ford red engine paint. That seems to be a close match. I just cleaned and coated the inside of one of the tanks I have. I Share this post Link to post Share on other sites
Coadster32 793 #7 Posted July 8, 2014 I have spilled plenty of gas on my WH hoods, and the paint hasn't peeled yet. Nothing special or fancy. I think curing is the real thing. Share this post Link to post Share on other sites
zieg72 209 #8 Posted July 8, 2014 Usually a 2K epoxy paint would have the best chemical resistance. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #9 Posted July 8, 2014 I never heard of a 2k epoxy.... Share this post Link to post Share on other sites
AMC RULES 37,254 #10 Posted July 8, 2014 Google search for "fuel proof paint" suggests either an automotive bc/cc or an epoxy paint. Share this post Link to post Share on other sites
zieg72 209 #11 Posted July 8, 2014 Epoxy paints come in one or two components plus a reducer. Single part epoxy paints are OK and are better than enamels for corrosion and chemical resistance but a true 2 part or 2K epoxy is best for chemical resistance. Oil refinery tanks that hold gas and components to make gas all are lined with special 2K epoxy systems. Where epoxy paints fall short is they don't do well in the sun, they chalk bad fast. That is where a 2K urethane topcoat makes an excellent system. CARC paint on Military stuff is a moisture cure or 2 K water based urethane with a 2K epoxy underneath... 1 Share this post Link to post Share on other sites
