mikemc53 10 #1 Posted July 2, 2014 OK, so the deck (36" side discharge) on the 1974 B-100 needs some work, which will be added expense and time. Center pulley assembly bearing is shot, the blades are pretty much gone too and the belt is on it's last legs. I will eventually do some repair but I have a question on deck interchangeability. Will the deck on my 1978 C-81 (36" rear discharge) fit the '74 B-100 - without any real modification? They are not at the same location (about 4 hours apart) so I can't do a side by side comparison. Whether or not they are interchangeable I still will either repair or replace the deck. Anybody in the Port Huron Michigan area have a deck that would fit the B-100 without a lot of work? Or parts to repair the one I have? Like most, I'm not looking to spend a ton but would like to have an operational deck for both tractors. Thanks gang. 1 Share this post Link to post Share on other sites
Desko 676 #2 Posted July 2, 2014 (edited) Yes they should.B,C,300,400,500 series as long as it has tach a matic. Edited July 2, 2014 by Desko Share this post Link to post Share on other sites
Lane Ranger 12,031 #3 Posted July 2, 2014 (edited) Yopu can still pick up good 36 inch decks for $50 to $150 at swap meets , yeard sales and online. The quality always varies but you already know what a good one looks and operates like. I have three back up decks -just in case! I never want to have to rebuild one before mowing! Edited July 2, 2014 by Lane Ranger Share this post Link to post Share on other sites
