toolmaker40
416-8 model #31-16k803 with deck#05-48ms05
toolmaker40
could anyone give me the shortcut to the mule drive pdf please I need to order pulleys for my dads 412-8
thanks
Kevin
zieg72
https://lookup3.toro.com/partdex/    Then type in your model of the deck 05-48SM05, you will get the exploded view.  Item 37 is part# 104975 Pulley-flat idler, and item 35 is part# 104974 Pulley-V
squonk
do you just need the bearings? I just replaced both of them in a mule drive. Cost around $20.00
v pulley brg is a Napa 7-04140,   Flat idler brg is a 3/4" shaft  x 12 mm thick x 40 mm dia. # 6203-2rs-12 got that off of e-bay. Just punch in the bearing sizes.
Edited by squonk
Tankman
Parts Tree has some ref' material, drawings and part numbers.
Take a peek-a-boo here: http://www.partstree.com/parts/?lc=Toro+Consumer&mn=E5-48SC01
And here: http://www.partstree.com/parts/?lc=toro_consumer&mn=E5-48SC01%2C+48%22+Side+Discharge+Mower%2C+1988&dn=3328-950-_9500022-0008
Same part numbers zieg72 noted.
Edited by Tankman
  • Similar Content
    • rustyedge1
      By rustyedge1
      Belt in photo is K Force brand A 102742 which is what my local parts place is pushing at 30 bucks plus.
      This one was bought two seasons ago counting this mowing season and it’s not going to make it looks like..
      Any info on better made belts appreciated..
    • Gettysburg Axel
      By Gettysburg Axel
      In search of a mule drive for a 60 inch deck for my 520. Located near central Pa or able to ship if possible. Also would be interested in trading parts for the mule drive if wanted.
    • 87 312-8
      By 87 312-8
      looking for mule drive bearings for a 36 inch rear discharge deck 1986/87 312-8, thank you
    • Joel
      By Joel
      My dad gave me his c105 with a plow attachment. I have taken the mule gear off to replace the belt, check bearings, and replace fasteners. Although now I cant seem to get the darn thing back on. I know I should've taken pictures b4 tearing into it. I guess I got too excited. If someone could send a pic of how theirs is mounted thatd be great!
    • Rock farmer
      By Rock farmer
      Are the bearings replaceble  by themselves?
      or do I need to replace the pulley?
       The inner vee pulley has a destroyed bearing.
      can I use a puller to remove the outer idler pulley?
      or will I destroy that one trying to get it off?
      they seem to be pressed on.
      are replacements available?
      thanks!
      joe
      I'm talking about a 1990 312-8 with a 42” deck.
