Cam-c121 6 #1 Posted May 29, 2014 So after the arrival of my second horse I decide it is time for the first one to go and thought I'd make my other the best it could be but after I changed the tie rods I've noticed the steering to be very sloppy and loose and for some reason there is a one wheel slightly points away. What could this be simply just a new set of tie rods ? Will try and upload a photo of the wheels at some point but photobucket seems to be playing up at the moment Share this post Link to post Share on other sites
Jparkes43 329 #2 Posted May 29, 2014 My steering wheel moves a lot without moving the wheels and it hasn't really affected me so I would say it's not the end of the world but of you want to make it better than I have no idea someone else will have to help. James Share this post Link to post Share on other sites
pacer 3,160 #3 Posted May 29, 2014 There are different lengths of rods, did you compare the new with the old? Thats the only thing I can think of to cause different toe in/out. Share this post Link to post Share on other sites
rmaynard 14,994 #4 Posted May 29, 2014 Did you replace the tie-rods with adjustable ones? If so, set the toe in about 1/8" after you check all the connections, tie-rod to spindle, and tie-rod to steering shaft. Make sure they are tight. Then check the front to back movement of the lower steering shaft. If it has a lot of play, it can be tightened up with shims on the shaft behind the lower steering support block. Share this post Link to post Share on other sites
Cam-c121 6 #5 Posted May 29, 2014 I took adjustable ones off and put non adjustable ones on but I didn't compare the lengths do you think it would affect the value much ? Share this post Link to post Share on other sites
Anglo Traction 759 #6 Posted May 29, 2014 Fixed length Rods are ok, but if there are any inaccuracies in the welded Lower Rod joints, the wheels will be out of line. Adjustable rods allow the inaccuracies to be compensated for. Bob's description of shim adjustment above is located in the 'Arrowed' area below the bracket in this pic- or in Illustrated parts format- I had a lot of problems with steering errors on my 74 C-120/Raider project which I covered in the thread here a while back. Share this post Link to post Share on other sites
