J HO 3 #1 Posted May 29, 2014 Started to disassemble my dads 520-H. This tractor has really been neglected for at least 15 years. Here are a few pics. Share this post Link to post Share on other sites
J HO 3 #2 Posted May 29, 2014 Lets try and load some pics again. 1 Share this post Link to post Share on other sites
J HO 3 #3 Posted May 29, 2014 Can anyone give me some Information from the ID#'s? I know it has a 20 hp Onan Engine What Year? I believe my dad bought it New in 1989? 520-HC? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,920 #4 Posted May 29, 2014 He could have bought it in late 1989 because it is a 1990 model. Go into the manuals a do a search for 41-20OE01 with a dash. 20 = engine hp O = Onan engine 01 = numbers zero one Garry Share this post Link to post Share on other sites
J HO 3 #5 Posted May 29, 2014 Thanks, I was having a hard time finding that information. 1 Share this post Link to post Share on other sites
Ed Kennell 44,096 #6 Posted May 29, 2014 How far are you going with the engine redo ? How many hours ? Has it ever been apart ? Share this post Link to post Share on other sites
rexman72 210 #7 Posted May 29, 2014 that will be a great project for you Share this post Link to post Share on other sites
Desko 636 #8 Posted May 29, 2014 Can wait to see her finished as long as the engine doesn't need a complete rebuild it should be good to clean it up on the inside and just put fresh gaskets and seals on it Share this post Link to post Share on other sites
edwroy 138 #9 Posted May 30, 2014 Toro parts look-up shows it to be a 1990. Share this post Link to post Share on other sites
J HO 3 #10 Posted May 30, 2014 It has 970 hours. The engine has never been apart (it was still running great). I have not decided how far I am going with the engine it does show evidence oil leaking from the gaskets. What are some of your recommendations? Valve Seals and Gaskets? Here are some pics of things that need to be fixed or replaced. What are some suggestions on how to repair the sub-frame? Thanks J Ho Share this post Link to post Share on other sites
Tankman 3,527 #11 Posted May 30, 2014 (edited) Looks like my '90 520-8 before I restored the poor old Horse. After a complete tear down, I sand blasted all before painting. New decals from, of course, the Vinyl Guy. Have fun with the project and be sure, we need to know and see, to post updates. Good luck! Edited May 30, 2014 by Tankman 2 Share this post Link to post Share on other sites
J HO 3 #12 Posted May 30, 2014 Thanks for the tip on the Vinyl Guy. I am new to this site and to restoring tractors. So any Tips on Parts would be Great. Thanks Guys J Ho. Share this post Link to post Share on other sites
Tankman 3,527 #13 Posted May 30, 2014 Here's a good link FYI. http://www.partstree.com/parts/?lc=Toro+Consumer&mn=41-20O801 Share this post Link to post Share on other sites
Ed Kennell 44,096 #14 Posted May 30, 2014 Onan Cummins should have all the parts you need. There are many recent posts here on 520 redos . I just finished my '88 520H. It is located in the tractors under "New ?..Find". Some of the common problem areas are ; Overheating of the rear cylinder .. remove all the tins and clean the cooling fins...while the tin is off, check for oil leak under the oil filter mounting bracket..a new gsket is available from Cummins for ~$4... There is also a gasket available from Cummins for ~ $5 to seal the OD of the filter to the tin to increase the air flow across the rear cyl. also I have vented the belt guard to allow the hot air to escape easier. Surging of the engine..... clean the carb, clean the carb, clean the carb Do a search of Onan surging or carb cleaning to find many threads on how to do this effectively. Electrical problems ...Clean all connectors , lugs, fuse blocks, etc. .. unplug and replug each one at least 3X ... New regulator/Rectifiers are available for ~ $25 If you encounter any electrical problems , post them here and our member electrical guru "SAVE OLD IRON" will guide you to a solution. Have fun with it ....Everyone is here to help 1 Share this post Link to post Share on other sites
J HO 3 #15 Posted May 31, 2014 Continued with the Tear down. Share this post Link to post Share on other sites
J HO 3 #16 Posted June 1, 2014 (edited) Here are some pics of my sub-frame repair. Original Bolts were tore out. Still have to mock up and drill holes. I added gussets for extra support. Edited June 1, 2014 by J HO Share this post Link to post Share on other sites
Martin 2,133 #17 Posted June 1, 2014 looking good so far!... one thing i would check with your repair in the last pic is does the belt guard fit right. maybe its just the position of the pic but it looks like you welded some sort of brace underneath the repair. the belt guard fits underneath that area and any extra metal is sometimes in the way. you maybe ok if back far enough to clear the belt guard. maybe you already considered that, but just thought id throw it out there...... 2 Share this post Link to post Share on other sites
J HO 3 #18 Posted June 2, 2014 Thanks, I still have to Mock it up. I tried not to have it stick much further down than the Bolt would stick. Share this post Link to post Share on other sites
Desko 636 #19 Posted June 17, 2014 Well any update on the old horse. Share this post Link to post Share on other sites
oneroadkingman 53 #20 Posted June 18, 2014 looks like a great project you got going on there. great pictures I have one of these myself maybe I will start ripping it apart in the near future it also has electrical issues. I won't start right now but like yours it was elected sat outside underneath a deck and I'm sure is a lot of corrosion and that's going on .we'll get it figured out with the help of some people on this site.great group of people here. looking forward following your progress might help me get motivated myself. Share this post Link to post Share on other sites
HorseFixer 2,014 #21 Posted June 18, 2014 J HO, TO I restored my 520-H a few years ago you can click on the link of the snow chucker in my signature. I went and rebuilt the complete engine and added a remote oil filter setup for the engine among many other modifications. Looks like its a great project you have going. For engine parts go to onanparts.com Tell TJ what your doing and He will help you with what you need. Good Luck ~Duke Share this post Link to post Share on other sites
J HO 3 #22 Posted June 12, 2015 Its been along time but here are a couple new pics. I painted the Black front last night. 1 Share this post Link to post Share on other sites
