chipwitch 73 #1 Posted May 28, 2014 Seems my tractor is missing a few springs. Is there a reference table or something that shows spring specs? Just the ones that have popped out at me so far are the tiller idler pulley (drive mule?) and the tiller lift assist. I saw one or two other small springs on the tractor that don't look like they belong there or they're the wrong ones. Be nice to double check their specs. If not, what do you do about replacing springs? Dealer only? Trial and error? Share this post Link to post Share on other sites
Save Old Iron 1,576 #2 Posted May 29, 2014 II have not seen a cross reference list but here is a possible source Share this post Link to post Share on other sites
chipwitch 73 #3 Posted May 29, 2014 Pretty much what I expected As far as lift assist springs go, I guess that's easy enough to calculate. Places like McMaster publish all their spring specs so selection isn't a problem. The bigger problem for me are the springs that maintain belt tension. I could determine that mathematically if I knew what the belt tensions were supposed to be. Are those numbers published anywhere? Share this post Link to post Share on other sites
KATO 115 #4 Posted May 29, 2014 i dont have a tiller but I have used the dealer on several other springs and the prices werent out of line Share this post Link to post Share on other sites
groundhog47 448 #5 Posted May 29, 2014 (edited) If you need the measurements I'll get it for ya, the part # is 4629 lift assist (pricy) and idler (back pulling) for attach by brake is 6135 (front pulling spring may be different). I'll get ya the big one length, but don't have a small one to go by. Kelly, a vendor member on here mentions in a post that the old car hood springs will prob work. If lucky enough to have a nearby Tractor Supply store they have a good assortment in stock usually. And to As for other springs I'm relatively new and haven't seen or haerd of a list yet, but tha would be a great idea. One member suggested we get a pulley size comparison, good idea also, but ..... Edited May 29, 2014 by groundhog47 Share this post Link to post Share on other sites
GlenPettit 1,719 #6 Posted May 29, 2014 Lift Assist Spring: (Snowthrower & Tiller) WH Part #8-4311 . . . . . . . . Used with front SNOWTHROWERS and rear ROTOTILLERS, to assist with lifting of these heavy implements: Springs are 7.75" long, 1.5" diameter, and made of 7/32" ( .220" ) thick Wire. The special High Temperature Annealing in the manufacturing process gives these extension springs a very unique high lift torquewhen under stress, making them much stronger than a Zinc or Chrome plated spring of the same size. Springs are painted Red. Share this post Link to post Share on other sites
SousaKerry 503 #7 Posted May 29, 2014 The big things to know when finding replacement springs are. Over all lenght maximum extension(or compression) spring rate outer diameter wire diameter number of turns material When some of these are known others can be calculated a couple of manufactures with extensive catalogs are Lee Spring, Associated Spring. There are also ANSI standard springs that meet predetermined criteria these are the springs usually found in hardware stores or places like Fastenal. Usually when I need one I take the remnants into a store like Fastenal and try to match it up the best I can with what is on the shelf and go from there. 95% of the time the spring you need can vary by quite a large margin and still work. At work when we are designing new equipment and a spring is needed we will often choose one from a sample kit and try several similar ones before finding the right one. We do this as the calculations do not always work the way you would think. Share this post Link to post Share on other sites
