DAVE L 31 #1 Posted May 21, 2014 Hi all, I live in NW Minnesota, and am planning on putting fluid in my tires. It will sometimes reach -45, and washer fluid in only good to -25. Will antifreeze work, or is there something else that will work to -45. Tires are 23 inch bar lug, 12 inch rim. Will not be used during winter months as of now. Thanks in advance! Share this post Link to post Share on other sites
GlenPettit 1,714 #2 Posted May 21, 2014 The very best product to use is "Rim Guard" (google it). It's 'Sugar Beet Juice'; organic, very safe for humans & nature, local. can take the cold, very heavy. At 80% fill; rear 23" tire takes 5.5 gal (60#) @, front 16" takes 2+ (24#) @. Actual cost is about $3/gal plus the filling cost (can vary a lot, compare carefully, shop around). Smart to use tubes, but not required, only use the better quality & thicker USA-made tubes, because the 'metal valve-to-rubber adhesive' is much better (has been problem with Rim-Guard). Fluid in tires is very smart, you can always add more weight (I have added nearly 500# to my Tiller C-416 with Ag's, on both front & rear). Be sure to add weight/fluid to the front tires, really greatly improves your steering control, you'll need it (Ribs are best, Ag's second best on front). Glen 1 Share this post Link to post Share on other sites
Jim_M 178 #3 Posted May 21, 2014 I had tires filled with used anti freeze that the local garage gave me for years. It worked great. 1 Share this post Link to post Share on other sites
DAVE L 31 #4 Posted May 21, 2014 The very best product to use is "Rim Guard" (google it). It's 'Sugar Beet Juice'; organic, very safe for humans & nature, local. can take the cold, very heavy. At 80% fill; rear 23" tire takes 5.5 gal (60#) @, front 16" takes 2+ (24#) @. Actual cost is about $3/gal plus the filling cost (can vary a lot, compare carefully, shop around). Smart to use tubes, but not required, only use the better quality & thicker USA-made tubes, because the 'metal valve-to-rubber adhesive' is much better (has been problem with Rim-Guard). Fluid in tires is very smart, you can always add more weight (I have added nearly 500# to my Tiller C-416 with Ag's, on both front & rear). Be sure to add weight/fluid to the front tires, really greatly improves your steering control, you'll need it (Ribs are best, Ag's second best on front). Glen I live near Sugar Beat country. Sounds like the ideal fluid to use. I have tri-ribs on the front and going to fill them too. I may also add wheel weights, and weights to the front. Thanks for the reply! Share this post Link to post Share on other sites
DAVE L 31 #5 Posted May 21, 2014 I had tires filled with used anti freeze that the local garage gave me for years. It worked great. This is another good option! I never thought of used! Share this post Link to post Share on other sites
