tom h.hill 10 #1 Posted May 9, 2014 i have model 1054. iget the tractor running adjust the carburator .get it running smoth and once i put in gear an take off it like chokes itself out. so i put my hand over the mouth of the carb it starts right back up idles and then it does the same thing again.i dont no.could it be the fuel pump.i checked the in line filter an its clesn same with the gas tank .its getting plenty of gas no blckage. Share this post Link to post Share on other sites
rmaynard 17,582 #2 Posted May 9, 2014 Do you have the governor hooked up correctly? Share this post Link to post Share on other sites
tom h.hill 10 #3 Posted May 9, 2014 Yes I am pretty sure I do. What's the chances it's the fuel pump How do I check the governer any how. Share this post Link to post Share on other sites
buckrancher 2,697 #4 Posted May 9, 2014 (edited) take the fuel line off the carb and crank the motor over to see if the fuel pump is working brian Edited May 9, 2014 by buckrancher 1 Share this post Link to post Share on other sites
Jparkes43 329 #5 Posted May 9, 2014 take the fuel line off the carb and crank the motor over to see if the fuel pump is working brian +1 on that but hand turn it over because using the starter will a be dangerous because of the electrics and b will put fuel everywhere. James Share this post Link to post Share on other sites
C-101plowerpower 1,606 #6 Posted May 9, 2014 +1 on that but hand turn it over because using the starter will a be dangerous because of the electrics and b will put fuel everywhere. James i won't worry about that, it doesn't produce a lot of pressure Koen Share this post Link to post Share on other sites
Jparkes43 329 #7 Posted May 9, 2014 i won't worry about that, it doesn't produce a lot of pressure Koen Ok it's just what I was told when I checked my pump. James Share this post Link to post Share on other sites
tom h.hill 10 #8 Posted May 9, 2014 alright headen out to see what i got.ill be back.thanks Share this post Link to post Share on other sites
buckrancher 2,697 #9 Posted May 9, 2014 if you are worried about a gas squirting out put a piece of rubber hose on the line and run it in a can Brian 2 Share this post Link to post Share on other sites
