Stu
Not new to Wheel Horse
Stu
I have not seen a single Wheel Horse tractor anywhere in the state of Louisiana...what gives?  If I see a Wheel Horse tractor along the road, I will slam the brakes on to go look at it.  Probably nuts like most of you.  This is how I found my C-141.  It was parked, forlorn, at a John Deere dealer in Grinnell, Iowa.  I slammed on the brakes "to have a look" and after a test run, I had the tractor delivered to my house later that day.  Back in 1966 Dad bought a brand new 606 from Caola's in Trenton, New Jersey.  (Caola's is still in business) I had a thriving lawn business at age 12, and was certainly one of the first Wheel Horse hot rodders.  The "peaky" Tecumseh 6 h.p. power plant could easily be coaxed well beyond its red line (whatever that was) and it sounded remarkably like a Ferrari 365 GTB at full song.  Remove the mower deck and spectacular wheelies were possible.  The higher horse power machines could not pull wheelies like the 606 because of their heavy Kohler cast iron engines.  By age 13 I could go from wheelie contest back to my lawn mowing business in minutes.  We even had a road course for our tractors in the woods across the street from our house.  Sadly, I destroyed the mighty Tecumseh and it was sent back to Caola's for a replacement.  I asked to keep the old engine, which I took apart and reassembled replacing only the head gasket.  ( I was only 12 after all)  That old Tecumseh went on to power Dads chipper/shredder well into the late 1980s...when he sold it.  So, who know Wheel Horse people in Louisiana?  I left the C-141 in Iowa and would like another C-141 or C-161 8-speed...
AMC RULES
Stu, you can always have a   :wh: shipped down there.
                   :WRS:
bowtieguy
Keep lookin'....some not far north of ya...might send one (or more) down south when the "snow birds" head your way for the winter!!!
Stu
Thanks Frank and Craig.  I have spotted some in Arkansas but finding a nice machine within a 200 mile radius would be great.  Pick-up and trailer is preferred.  I would be open to shipping one down here from up north to get the right machine.  C-161, 141 preferred with a 48 inch mower deck.  I also prefer the 8-speed over the hydro.
pacer
Stu,
There are 2 horse nuts quite near you. Im Bill Pace out in Greenwood and groundhog44 (Gerry) is in Shreveport, we're both retired and dabble in WH's a lot. In fact just this morning we were in my shop doing machine work for an 8 speed.
I have a D-180, a D-160, and a C-175 running and about 3 other rollers, just sold an extensive re-furbed 1054 and a C-100.
Send a PM and we'll exchange contact info and maybe we can locate you a horse.
Stu
Hi Bill-  I work with a guy named Bill Pace.  Any relation?    What I want to do is replace the C-141 with 48" deck I sold up in Iowa...without having to go to far to get it.  It will have to be ready to work and be clean and in good repair.
Amanda
Welcome to red square!!
Sparky
The member map shows at least 3 members from your state....add yourself and make it 4!
Maybe you should count your blessings....if a Wheel Horse comes up for sale on Connecticut Craigslist there's about 50 guys all over it....ASAP!!!
:WRS:
Mike.............
AMC RULES
Yeah boy...the more, the merrier.   :handgestures-thumbsup:
Jake Kuhn
:WRS:
  • Similar Content
    • 1054 Project
      By 1054 Project
      OK, I have my new return spring. As you can see the overall length of the replacement spring is much taller than the old one. I assume I'll need to shorten the spring so that it engages with the outboard holes and at the same time have the "U" sit behind the roll pin. Or am I looking at this all wrong?
      Thanks in advance!
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
