tommyg
Steering Box Grease Hog
tommyg
My D-180's steering box grease reservoir must have a hollow leg. I've pumped more grease into that thing expecting to, at some point, see it ooze out somewhere to know it's filled. I've yet to see any grease! Is it possible it's filling in the tube that that the steering shaft runs through? Or could it be that empty?
cleat
My Ford LGT has a similar Ross gearbox that I have greased regularly for over 10 years now and have yet to see grease come out. Where it goes I don't know.
Cleat
pacer
The box is a good sized cavity, probably would hold over half a tube of grease and IIRC from going in mine, once it fills, the grease would probably start trying to fill the steering shaft tube :eek:
tommyg
Well, after 350 strokes from a pneumatic grease gun, it finally started oozing out like I expected. That thing must have been dry!
Hodge71
Yikes!!! :scared-eek:  :scared-eek: I need to grease mine. I sure hope its not that dry. Theres actually a ton of maintenance I need to do to my 18 Auto gear box. Definitely needs some love
cleat
To grease my Ford I needed to take off the deck and crawl up underneath so I added a section of hose from a grease gun and put a grease fitting on the end so now greasing it is a breeze so I do it quite often now.
Cleat
Duff
Cleat
Now that is one great idea! As I get older, crawling under and reaching through equipment is getting harder. I'll give this a try!  :thanks:
Duff :thumbs:  :thumbs:
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • ihatephones
      By ihatephones
      I got a D-180 for $250, and the governor is messed up, the points won't open or close, and I took it apart and was being stupid and messed some stuff up in there, and now I need a new one.
      Where can I get one that's not on eBay for $200?
      I also forgot to say it was a Kohler K482, and I'll throw some pictures of the tractor in as a treat.
    • Brandon Byers
      By Brandon Byers
      I know I'm half a year ahead of schedule!
      I picked this 1974 D-180 up early last year. It had a pretty hard life, and the previous owner gave his best attempt at keeping it alive. Hydro was strong so I serviced it and put it to work mowing all year. I decided if it would make it through the season then it would get some TLC. By fall it was burning about a quart of oil an hour but it made it. I have no clue how many hours are on it, every hole, bushing, bearing on this tractor is pooched. If you look closely, somebody used two 1" NPT Pipe Flanges to rebuild the mounting points for the upper 3 point cylinder. Hey it works!
      I rebuilt the steering gearbox and re-bushed the front axle along with making new spindles.
      I had the 482 Kohler bored .20 over (it was .10 over already) and gave it a rebuild with the intention of putting it back to work on snow duty.
      I then dawned on me that this tractor will be 50 years old next year - and these old D's are becoming harder and harder to find anymore. So I decided to customize it a bit and go for what a maybe a dealership would offer for a 50th anniversary model if Wheel Horse was still in business today (In another universe, maybe!)
      As D's aren't known for their looks - and I can't leave anything alone. I took approximately 2 Inches out of the grille and bezel.
      I updated most of the wiring and lights. Gave it a new set of Carlisle Ags along with Vredestein front ribs. It got a new seat and I painted all the accents aluminum.
      I patched, rebuilt the 48" deck and put new blades, wheels, and hardware on it. The Blade & 3 point scoop somebody adapted to it also got some attention.
      Lastly I stripped it most of the way down and painted it with IH red acrylic urethane enamel.
      I always forget to take pictures during my projects but here's a few:
      Before:
      After:
      Thanks for reading!!
    • Crazy Old Red Horse
      By Crazy Old Red Horse
      Barn find 1975 D180. 608 original hours. Tractor and 48” belly mower look to be still in their original paint. Rear 60” finish mower looks like it has had one coat of new paint added at some point. Open to trades. Please email me with any questions or for additional photos. 35 miles north of Pittsbugh.
    • Barcaskey
      By Barcaskey
      I have a D-180 that broke an axle I have got all new parts and have removed transaxle from machine.  The 2 parts I am missing for re assembly are the metal screen with magnet for inside trans  and a new gasket from transaxle to pump.  I have done some looking and can not find these parts.  I have the old screen but the rubber gasket on the end of it has some rot and is apart from the screen.   The gasket is still in place but i would feel better putting in a new one before re build.  Thanks for your help
