JimD 3,347 #1 Posted September 19, 2008 hi all, my neighbor has a k321s kohler. it's on a gravely 1450 super chief. the engine model no. is 2158919, spec no. 6013B. the carb is pretty damaged, in fact it may be fubar. i'm hoping some of you may have some idea where we might find one, or if someone here has one to sell? i'd like to help him out if i can cause he's a nice guy, but a little like that one tack that just keeps fallin off the bulletin board, if you know what i mean. but i have learned one thing from this forum, and that is that you help where you can, thanks in advance for any advice or help, jim. Share this post Link to post Share on other sites
kpinnc 15,669 #2 Posted September 19, 2008 They show up on Ebay pretty often. I'd cruise any local small engine repair shops too. Kevin Share this post Link to post Share on other sites
Electro12WH 50 #3 Posted September 19, 2008 What is damaged? The main casting? Most things can be fixed or replaced. Even a worn out throttle shaft hole is repairable. Share this post Link to post Share on other sites
JimD 3,347 #4 Posted September 19, 2008 the dhoke plate is siezed, the float is crashed, and it looks like it has a little crack in the body above the float, can't really tell because it hasn't be cleaned. the tractor is really in pretty good restorabl shape, but he just wants to plow snow with it. is there a rebuild kit for it if it isn't cracked? thanks, jim. Share this post Link to post Share on other sites
Electro12WH 50 #5 Posted September 19, 2008 Sure, there are rebuild kits. First disassemble as much as possible. The choke and throttle plates have screws that have been peened over so remove without damaging. It's kind of hard to find new screws. Then soak the carb in a carb cleaner. Available at auto parts stores. This may loosen the choke shaft. When you pull out the choke shaft, there is a ball and spring that may be lost if your not careful! After cleaning, the crack may turn out to be just a casting flaw. Share this post Link to post Share on other sites
