gentle man farmer 0 #1 Posted April 29, 2014 Just picked up a c-81 with a mower deck that needs some work its model number is 95-36mr00 I am trying to find parts for the spindles my question is the 95-36mr01 thw same deck part wise thanks this project is going to take me a while Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,013 #2 Posted April 29, 2014 The only thing I can find is in the spindle Charts. 95-36MR01 uses different spindle assemblies than the 95-36MR00 85-36MR01 uses same spindle assemblies as 95-36MR00 Chart Garry Share this post Link to post Share on other sites
gentle man farmer 0 #3 Posted April 30, 2014 just got it all apart all the diagrams shoew snap rings mine does not have them or space to put them and the spindle housings are fined looks like alum. just need a number for the bearings and the seal I have access to lots of suppliers so even a timken number will work iwill try to post pics when i can take some raining here thanks all for any help the old tractor starts and runs real good Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,013 #4 Posted April 30, 2014 Are you sure you don't have the one-piece bearing and shaft # 103119 illustrated in diagram "D". Toro has discontinued that one but it is still available through Stens, Napa and other suppliers for lawn equipment. A Google search should bring up many results. This style is often called a water pump bearing. Garry Share this post Link to post Share on other sites
groundhog47 447 #5 Posted April 30, 2014 (edited) Does one of these pics look like your spindle, the first has bearings like Garry said, second has ball bearings. If pulley shaft on second is 5/8" and non keyed, metric; if 3/4" keyed shaft, standard bearing. Will get you a number. Poss the PO upgraded spindles like did on mine. Top bearing if 3/4" shaft: on ...MR01 diagram, #19=106085 unsealed top and bottom. Bot bearing if 3/4" shaft: on ...MR01 diagram, #25=106084 sealed bottom, open top. Top seal: on ...........................MR01 diagram, #17=106075 There should be a snap ring on bottom of spindle that retains bottom bearing, if not it's either ground off end (dirt and debris under cup will do that) or just missing, but necessary. Best bet remove bearing, carry to good bearing supplier and let them match, a whole lot less expensive, an you can remove rubber seal with a little sharp tool Save the seal as can also be added back). Bearings Limited #6203x3/4 2RSC3 PRX is what I purchased (not metric 6203). Seal: NOK AD8213E (Singapore). Take a shaft along If you have trouble finding seals or snap rings, or have a bad shaft, send me a PM. Edited April 30, 2014 by groundhog47 Share this post Link to post Share on other sites
Tankman 3,528 #6 Posted April 30, 2014 For quick reference, I like Parts Tree; http://www.partstree.com/parts/?lc=Toro+Consumer&mn=E5-48SC01 Share this post Link to post Share on other sites
gentle man farmer 0 #7 Posted April 30, 2014 mine looks like the second one want to thank every one for all the great info will get some pics of the old girl and post them i will be looking for lots of parts as I go forward Share this post Link to post Share on other sites
daveoman1966 3,882 #8 Posted May 2, 2014 I have the bearings for that spindle and will send a PM to you about them...and the spindle. 106084 and 106085 My direct email is: daveoman@windstream.net Share this post Link to post Share on other sites
