AJRULEZ13
wheel horse b82
AJRULEZ13
Hey I own a wheel Horse model B82 with a Briggs and Stratton 8hp motor and have been thinking of restoring it and was wondering if it was rare or not and if it would even be worth restoring.
Edited by AJRULEZ13
Sparky
Not rare in my opinion. As far as restoring goes, if your doing it for your own pleasure and satisfaction go for it....if you are thinking about restoring it and flipping it to turn a profit forget it. You will be over invested in a non-collectable machine.
  :WRS:
  Mike......
JERSEYHAWG /  Glenn
AJ. How about a few pics to see it. Ty.
Glenn
AJRULEZ13
thats depressing i want to restore it for a personal item to have fun with but i was hoping it would be rare and ill try to get some pictures for you
  • Similar Content
    • rustyedge1
      By rustyedge1
      The local place I’ve bought parts from for years has changed owners, now they can’t even spell Wheel Horse let alone be if any help.
      Doing my spring tune up I noticed my drive belt is getting pretty ratty. Due to all I’ve read thought I’d ask for some advise on getting it right the first time on a new belt.
      Is there still dealers on this site selling OME stuff ? I know there are tons of aftermarket crap but not looking for that.
      Thank in advance.
    • rustyedge1
      By rustyedge1
      Need a condenser for engine shown in photos 8 hp Kohler. Any venders carry them on this site ?
      All help appreciated..Have PayPal or can send check..
    • WheelPuke
      By WheelPuke
      I have my 25A fuse blowing every time I put a new one in the slot. The old one was burnt up when I got the tractor put this year. It sat for a year with a dead battery. I stopped using it as much because the transmission is clattering pretty bad when taking off on second or higher. I had to replace the clutch belt a few years ago and couldn't get an OEM. Not sure what is the problem there that's another issue though.
      I have checked the wiring and patched the worn spots where it could be grounding out. The fuse blows as soon as there is power to the system with the ignition off. I'm at a loss of what to check for at this point. Any input from someone who has had this issue would be appreciated. I'm not sure what these units are in the photos but do not know how to test them for a failure. They are directly in loop with the battery and the ignition loom looks to run into that 25A fuse.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
