slammer302 2,156 #1 Posted April 13, 2014 I just got a 416-8 from bowtieguy and it has some wireing problems but I have were I can start it up but the carb keeps flooding its self out I have to turn the pump on and off every few seconds to keep it running if I keep the pump running gas just poors out from the five little holes around the top of the carb I never messed with these carbs before so I am looking for sum insight on how to tear in to this thing Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted April 13, 2014 Hers a pic Share this post Link to post Share on other sites
rmaynard 16,837 #3 Posted April 13, 2014 (edited) Sounds like the float is stuck down or has a hole in it, and the float valve is not closing. Time to take the bowl off the bottom of the carburetor and have a look. Edit: Just deciphered that you have an Onan. Not sure about that one, but I still think it's a float issue. Edited April 13, 2014 by rmaynard Share this post Link to post Share on other sites
slammer302 2,156 #4 Posted April 13, 2014 Yeah I've never taken a onan carb apart Share this post Link to post Share on other sites
Desko 644 #5 Posted April 13, 2014 You don't have to take the carb off just take the filter box off and pop the top of the carb off and inspect the problems it might be corroded or the float valve might be bad causing the fuel to keep flowing. Share this post Link to post Share on other sites
slammer302 2,156 #6 Posted April 13, 2014 Ok I go check it out and I'll keep you updated Share this post Link to post Share on other sites
bowtieguy 334 #7 Posted April 13, 2014 Yep...got to be a stuck float....forgot to tell you that I put a new elec fuel pump on it....(price would have gone up if I had remember that..lol) Todays fuel is all crappy stuff....when you take the top off of the carb you will see what ethanol does....grows GREEN mold on everything! Think you will like the 416 when you get all the bugs worked out.....you can tell the PO had never heard of "PM" PS....remember to bring a bigger trailer the next time you come visit the Horse Barn!!! 1 Share this post Link to post Share on other sites
slammer302 2,156 #8 Posted April 13, 2014 Yeah I got alot of black tar looking stuff out of the gas tank I think I got the carb fixed it will run under its own power now with half choke but I does sound good when I get some more time I think I will get it right . WHO hooo!!!!!! Dad is already wanting to plan another trip!! 1 Share this post Link to post Share on other sites
HokieAg07 129 #9 Posted April 13, 2014 As the owner of several Onans I will tell you one thing, for them to run well CARB MUST BE CLEAN!!! Share this post Link to post Share on other sites
Ed Kennell 44,607 #10 Posted April 13, 2014 I had to clean mine twice before I got it running right. Make sure all the holes are open and clean. You can get the bottom half of the carb off without removing the manifold. I just takes a little wrench flipping to get the two bottom bolts out. Share this post Link to post Share on other sites
Ed Kennell 44,607 #11 Posted April 13, 2014 Here are a couple pics. Make sure the holes below the throttle plate are clean. 1 Share this post Link to post Share on other sites
slammer302 2,156 #12 Posted April 13, 2014 Let my son loose on it today Share this post Link to post Share on other sites
