Nathanielperz 150 #1 Posted April 12, 2014 Hey guys im hoping to start the process of restoring my 1276 in a few weeks but I need some tips on how to get the paint off. I have sanders and stuff but I don't want to sand through the metal. I don't have a big enough air compressor for a sand blaster, or so my dad says. ( I did see these plans to make a sandblast with a Gatorade bottle) you guys got any tips for me? Thanks in advance- Nate Share this post Link to post Share on other sites
redrooster 83 #2 Posted April 12, 2014 I combined two smaller air compressors to give me enough capacity for a hand held sand blaster. You can save a lot of time and get all the nooks and crannies that sanding misses. 1 Share this post Link to post Share on other sites
Nathanielperz 150 #3 Posted April 12, 2014 Cool thank you I don't know how to do that but I will tell my father. Nate Share this post Link to post Share on other sites
redrooster 83 #4 Posted April 12, 2014 Just put a tee in the outlet of one unit and tie them together. Any questions ask me. Share this post Link to post Share on other sites
Nathanielperz 150 #5 Posted April 12, 2014 ok I will thank you Nate Share this post Link to post Share on other sites
C-101plowerpower 1,606 #6 Posted April 12, 2014 you could also use empty gas bottlel/tanks as an aditional airtank Koen 1 Share this post Link to post Share on other sites
JT Burkard 4 #7 Posted April 15, 2014 I am no expert but i have done some paint prep on cars in the past. I don't think you should have any worries about the sander going through the metal. A palm sander would work fine. Just make sure you use the right grade sand paper. A wire wheel would be ideal for you. I actually just started removing paint from the frame of my GMC General semi tractor with a wire wheel on a drill. That will work very well for your application. Easy to use and you won't have to keep changing sandpaper out. Share this post Link to post Share on other sites
Wishin4a416 2,561 #8 Posted April 15, 2014 I always start with aircraft stripper available at most auto parts stores. Then to the blaster or sander depending on size. I am lucky that at work we have a good hood with lots of air draw for stripping. If you use stripper, take the proper precautions! Share this post Link to post Share on other sites
