formariz 12,378 #1 Posted March 30, 2014 Usually old points have developed a sharp pointed protusion on one side, and the exact opposite on the opposite side. Does that condition affect timing on engine? If not replacing points, should it be filed flat and timing reworked? Many thanks. Share this post Link to post Share on other sites
rmaynard 17,229 #2 Posted March 30, 2014 I am not at my computer, but the Kohler manual does explain the question that you are asking. Share this post Link to post Share on other sites
oldredrider 2,553 #3 Posted March 30, 2014 File the points flat and re-gap to .019. Replacing the condenser should correct the problem. Share this post Link to post Share on other sites
formariz 12,378 #4 Posted March 30, 2014 File the points flat and re-gap to .019. Replacing the condenser should correct the problem. I thought it was just normal wear did not realized that it is caused by condenser! Share this post Link to post Share on other sites
rmaynard 17,229 #5 Posted March 30, 2014 (edited) Back at my computer where I have access to my Kohler manual. To confirm what Paul said, here is a snapshot from the manual: Edited March 30, 2014 by rmaynard Share this post Link to post Share on other sites
Retired Wrencher 6,732 #6 Posted March 30, 2014 Back at my computer where I have access to my Kohler manual. To confirm what Paul said, here is a snapshot from the manual: points transfer.png Bob what does over or under capacitance mean???? Gary Share this post Link to post Share on other sites
Racinbob 12,996 #7 Posted March 30, 2014 A capacitor stores electrical energy until the points discharge it. Capacitance relates to the amount of electrical energy a given capacitor can store. The term for it is farad. If I recall correctly from working on cars the capacitance rating was stamped on the condenser. Share this post Link to post Share on other sites
rmaynard 17,229 #8 Posted March 30, 2014 (edited) Generally Gary, it means "bad condenser". Edited March 30, 2014 by rmaynard Share this post Link to post Share on other sites
Retired Wrencher 6,732 #9 Posted March 30, 2014 Generally Gary, it means "bad condenser". ok thanks so no build up means good condenser???? Share this post Link to post Share on other sites
pfrederi 20,675 #10 Posted March 30, 2014 ok thanks so no build up means good condenser???? If you have spark and no build up/pitting the answer is yes Share this post Link to post Share on other sites
Ed Kennell 46,234 #11 Posted March 30, 2014 I believe the Kohlers require a 2 microfarad capacitor (condenser). Share this post Link to post Share on other sites
formariz 12,378 #12 Posted March 31, 2014 Thank you everyone.Great to always be learning something. Share this post Link to post Share on other sites
shorts 182 #13 Posted March 31, 2014 Just my opinion, but if you need to service the points and/or condenser replace them as a set, they are relatively cheap and considered consumable parts along with sparkplugs air filters belts and engine oil. If you need to file or clean the points to get running until you can get new parts consider it a temporary repair . 1 Share this post Link to post Share on other sites
Mr. 856 170 #14 Posted April 1, 2014 While we are talking points......I have a set that came off an engine that are brown plastic. the new set in the Kohler tune up kit that are on the engine now work but seem to be a lot more "sloppy" then the ones that came off. the new are black plastic.....and when the engine is running the points have a tendency to move outward on the shaft making the points not meet perfectly. It doesn't seem to effect the operation of the engine though. Is there a way to tweek the new points to make them stay aligned fully? It just appears to me that they move on the shaft more then the brown ones did or do. any thoughts? Would you consider putting the old ones back on? They worked just fine when removed. Share this post Link to post Share on other sites
BOWTIE 226 #15 Posted April 1, 2014 I WAS TOLD YEARS AGO BY IGNITION REP. THAT IF THE POINTS JUST WEAR OUT THE CONDENSER IS EXCELLENT AND DON'T REPLACE JUST THE POINTS. IT IS SOMETIMES HARD TO FIND A EXCELLENT TO MF SPECS ON A CONDENSER. I HAVE USED POINTS UP TO 1000 HOURS THAT JUST WORE EXCELLENT. BOWTIE Share this post Link to post Share on other sites
formariz 12,378 #16 Posted April 1, 2014 Has anyone used the Point Saver from Kirk engines?Seems like the ideal thing since it also helps to set the timing. Share this post Link to post Share on other sites
illinilefttackle 399 #17 Posted April 1, 2014 Has anyone used the Point Saver from Kirk engines?Seems like the ideal thing since it also helps to set the timing. Thats the first thing I did to my C-125 , K-301as when I rebuilt it- I liked the idea of it reducing the voltage at the points & it had a "Bonus" of being able to use the light as a timing device for the engine-new points & "Points Saver have been going 5 years now with no problem. Highly recommend it-Al Share this post Link to post Share on other sites
