grinchsr 669 #1 Posted March 25, 2014 Sorry for this dumb question but I never owned a tiller before. Do I need a clevis hitch to mount to a 312? I have one that was used with a B60. Share this post Link to post Share on other sites
Dieselcowboy 211 #2 Posted March 25, 2014 No a clevis hitch it not needed, but you will have to have the snow plow axle bracket to mount a tiller. Share this post Link to post Share on other sites
grinchsr 669 #3 Posted March 25, 2014 THANK YOU That is good news because now I do not have to try to find one Share this post Link to post Share on other sites
groundhog47 448 #4 Posted March 25, 2014 (edited) As discussed in there are two axel mounts for tillers. The older-older model may attach to newer mount but the idler is required, newer tiller has idler on tiller a frame. Reviewed question and see I didn't say should only use one of those axel hitches mentioned, but does need a lift cable, rod, or chain from implement lift mechanism to tiller lift point (3 types/attach points for lift). I,m guessing should be even swap. Edited March 25, 2014 by groundhog47 Share this post Link to post Share on other sites
