PMaine 31 #1 Posted March 25, 2014 I've got a problem, one that I am really glad I noticed. I've got a 516H that now has an Eaton 1100 in it- the drive belt tension pulley is making contact with the hard hydraulic pipe as shown. It appears that if I used a shorter drive belt the pulley would be raised and out of contact with the piping. Having said that, anyone have a Napa part # for the proper drive belt? I assume the eaton 1100 uses a different belt than an eaton 700 equiped tractor? Or am I missing something? Thanks guys Share this post Link to post Share on other sites
PMaine 31 #2 Posted March 25, 2014 Did some research, looks like Toro #114895 is the belt used on the 516 (eaton 700) and the 520 (eaton 1100), so not sure what the deal is. Share this post Link to post Share on other sites
Navig8r 132 #3 Posted March 25, 2014 Did some research, looks like Toro #114895 is the belt used on the 516 (eaton 700) and the 520 (eaton 1100), so not sure what the deal is. Dealer up the street from me has a bunch of OEM parts on E-bay, and that is one of em, $35.00 with free shipping. seller is majesticshardware255 if you are looking for a source. Share this post Link to post Share on other sites
PMaine 31 #4 Posted March 25, 2014 Thanks. I just bent the tensioner bracket enough to clear it for now. 2 Share this post Link to post Share on other sites
pfrederi 20,672 #5 Posted March 25, 2014 I noticed the same issue must have occurred on my 418A as there is a groove in my hard line also. There is possibility that the spacer on the bolt that holds the idler has worn down (or the slot in the handle the spacer rides in has worn) allowing the idler to move in closer to the frame.) On my 418A the spacer was gone and the slot in the handle was wallowed out. (Spacer is item 44 in diagram) Share this post Link to post Share on other sites
varosd 1,185 #6 Posted March 29, 2014 I noticed the same issue must have occurred on my 418A as there is a groove in my hard line also. There is possibility that the spacer on the bolt that holds the idler has worn down (or the slot in the handle the spacer rides in has worn) allowing the idler to move in closer to the frame.) On my 418A the spacer was gone and the slot in the handle was wallowed out. (Spacer is item 44 in diagram) My Eaton 1100 equipped Workhorse tranny engagement lever (part # 49) had worn out the back of the idler pulley slot and it came up and out of the shifter plate when I pulled up on it! got a used one of sleaze bay and back into operation. not sure why it happened, but like Paul stated, make sure it all wallowed out or like mine missing a chunk o" metal! Share this post Link to post Share on other sites
PMaine 31 #7 Posted April 17, 2014 Interesting guys, I don't have a lever (#49) at all. Photos to follow in a day or so! Share this post Link to post Share on other sites
