razu
another newbie
razu
Ok so im another new guy on here, although ive been somewhat of a stalker for a while
started out lookin for somthing a little tougher as i keep rippin trannys and rear gears outta mowers ,i have pretty rough/hilly yard
but after lurkin around here i can see this goin to another level!!!
I just bought a 310-8 model 21-10k806  yesterday I think original 42" deck from 1989 and i would like to find a backup belt or at least part#
mine looks a bit rough
Thanks Rusty
post-12699-0-44648300-1395258551_thumb.j
Jparkes43
I like it. Welcome to red sqaure hope you find the forum very useful with any questions you have.
James
gwest_ca
Welcome to the forum.
The tractor drive belt is Toro # 7473. Best to get an original from Toro if you can.
42" rear discharge drive belt is Toro # 108834
Spindle belt is Toro # 106125
42" side discharge drive belt is Toro # 94-2501
Spindle belt is Toro # 6738
Decks are sized by their width of cut - not the width of the deck. Are we on the same page?
Garry
AMC RULES
:WRS:
razu
Thanks guys
what about the deck drive belt or is that the number you give me
gwest_ca
Added the mower belts to the original post.
Garry
razu
Garry
awsome thanks Gary
im gonna take another look at the deck the shop i bought it from thought it was 44" but i didnt see those available anywhere
Thanks again
JERSEYHAWG /  Glenn
Rusty...best of luck and well come. The fun has just begun.
Glenn
gwest_ca
If this deck has a 2 blades it is a 37" side discharge deck and the above belts are wrong.
If it is 37" cut how many sides to the belt? 4 or 6?
The 4-sided belt is a regular belt.
The 6-sided ones look like 2 regular belts bonded back to back.
Garry
dennist
Welcome to RS.
limited12
Welcome to Red Square
rexman72
glad your not stalking anymore
KATO
WELCOME TO :rs: and they are very tough little tractors :handgestures-thumbupright:
KC9KAS
:WRS:
Looks like a nice GT you have.
Sparky
:WRS:
The deck in your pictures looks like a 37" side discharge to me. Is there a model# tag on it?
Mike.............
chazm
:text-welcomewave:  TO :rs:
Wheel-N-It
Congragulations Rusty! The 310-8 is a great "Starter" Wheel Horse!
razu
Ok i finally got around to checkin this out it is 37" with two pulleys and 6 sided belt
all i can make out on the tag is the last five numbers 11916
belt is cracked and i would say stretched out judging by the adjustment appears to be at the end of travel
thanks again
Stigian
Welcome to RedSquare. The 300 series are great machines, my 312 has served me well for many a year :handgestures-thumbup:
gwest_ca
thanks again
Mower deck is model 05-37SC01
Drive belt Toro 111178 [HA/Ax140.5"]
265-001 Stens 1/2"x140-1/2" Double-V
Follow this bulletin when installing the belt
Parts list
Operator manuals
11916 appears to be a 1989 serial number.
Garry
razu
thanks a ton i apreciate the time spent for all the info
JC 1965
Hello Rusty and  :WRS:
  • Similar Content
    • Fordiesel69
      By Fordiesel69
      Looking for the OEM nelson muffler that fits the Kohler Magnum M10 thru M16 engines found on the following tractor list:
      310-8
      310-H
      312-8
      312-H
      314-8
      314-H
      410-8
      410-H
      412-H
      412-8
      414-8
      414-H
      416-8
      416-H
      and also and "A" models that had the kohler magnum.
      I dropped mine off to be welded and it came up missing.  It was not good to begin with so im sure they accidentally tossed it out with the way it looked.
    • OHLB
      By OHLB
      Newbie here. 310-8 won't start. Battery is dated 10/19. Did crank a couple times but started losing ummph. Should I replace it or attempt to charge it? Can't tell if the battery is frozen. Never knew until today that batteries could freeze and that it's dangerous to charge a frozen battery. It's been single digits with wind chill the last couple weeks here.
    • Big Rig
      By Big Rig
      ISO clutch neutral safety switch for 310-8
      or alternative
    • Rob R
      By Rob R
      Soo couple of years back did a pulley change on the tranny from 6 inch to 4.5 and used a 1/2 X 79 belt to make it work and it worked fairly well but wanted to get back to a 5/8 drive belt so went to a 5/8 x 81 inch belt and added a second flat Idler pulley. I simply cannot believe how smooth and sharp it shifts and drives now!  The added flat Idler was 2 3/4" with a 5/8ths bore used and existing hole on the side shroud and just opened it up a bit. I use to slip a bit on steep hill with the 79" slips no more, the belt drives and the clutch is  LOT smoother and in the right pedal area.... Will see how it holds up cut 3/4 of an acre of grass yesterday NO issues.
    • Ifixoldjunk
      By Ifixoldjunk
      So I was out mowing the other day with my 310-8 and somehow snagged my wheel in a hole in the yard. Anyways I pretty much destroyed my ball joints. I've since replaced the tie rod with junkyard parts but I was wondering if anyone's found a heavy duty aftermarket replacement for the tie rod assembly.
      Like would generic adjustable go-kart tie rods do the trick?
