slammer302 2,157 #1 Posted March 14, 2014 The fuel pump on my 16 HP Kohler looks a lot bigger than the one on my k241 will they interchange Share this post Link to post Share on other sites
Kelly 1,038 #2 Posted March 14, 2014 The 10 to 16 hp kohler horizontal shaft engine pumps will interchange, you may have a metal and a plastic pump, the plastic pumps are bigger in size than the metal, but should supply the same amount of fuel. Share this post Link to post Share on other sites
slammer302 2,157 #3 Posted March 14, 2014 Its metal but it is larger Share this post Link to post Share on other sites
rmaynard 17,231 #4 Posted March 14, 2014 I have seen metal fuel pumps that had larger bodies, but the flange and pump lever were identical. If your mounting flange and lever are the same on the K241 as they are on the K341, you should be able to interchange them. The new part number for a fuel pump to fit K241 through K341 is 47 559 11-S. Share this post Link to post Share on other sites
slammer302 2,157 #5 Posted March 14, 2014 The one I have is a 47-393-04 Share this post Link to post Share on other sites
rmaynard 17,231 #6 Posted March 14, 2014 Here are drawings of four of the pumps that Kohler had on their K241 through K341 engines. The 47-393-04 pump is the one on the right according to the Kohler parts diagram. Share this post Link to post Share on other sites
slammer302 2,157 #7 Posted March 14, 2014 Thats what I needed to know I'm just going to put one on it from another motor. The one that is leaking everywhere is the one to the right of the pic Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #8 Posted March 15, 2014 The Carter "severe duty" pump can be replaced by a comparable standard pump. 241 through 341 & M10 - M16 pumps are interchangeable. Carter pump: Standard pumps: Share this post Link to post Share on other sites
KC9KAS 4,746 #9 Posted March 15, 2014 Thanks guys...Pictures speak a thousand words! Share this post Link to post Share on other sites
